tail light wiring - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
tail light wiring
Old 09-05-2011, 08:16 PM
Gordon-0 Gordon-0 is offline
Gordon-0 is starting off with a positive reputation.
tail light wiring
i was wondering if anyone had any wiring info for the rear tail lights on an 03 f250 xl
i have two black wires, one brown, one orange/gry and one pinkish/blk.
my haynes manual says that there should only be brown and grey for basically everything
any help?
Old 09-05-2011, 09:04 PM
dchamberlain's Avatar
dchamberlain dchamberlain is online now
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
I don't know what the black wires are, but the brown is tail/running lights and the orange/grey and pink/black are turn signals.
Where are you seeing these?
Old 09-05-2011, 09:21 PM
MOpartsguy's Avatar
MOpartsguy MOpartsguy is offline
MOpartsguy is starting off with a positive reputation.
There should be a pigtail to the driver's Rear underneath of the bed frame, almost above the spare tire. I just had the whole harness out to rewire mine for the goose neck AND the bumper hitch. I don't think your looking at the correct harness, but mine is a '99. I would assume they stayed the same thru 04 at least. There will be a total of 7 wires, however some/all may be taped back into the loom depending on your current setup.
Old 09-05-2011, 09:42 PM
Those 7 wires are for the trailer connector. They are separate circuits from the tail lights themselves.
The black wires are the grounds. I missed those on the diagram the first time around.
Old 09-05-2011, 09:50 PM
MOpartsguy's Avatar
silly me, He said Haynes and i was thinking trailer connectors, not repair manuals.
Old 09-06-2011, 09:29 PM
yeah, i bought a haynes to help out with stuff but so far it has proved useless.
so,
the brown wire comes on with the headlights only?
im trying to wire some aux lighting with the headlights
out of curiosity, how do the brake lights work?
i accidentally used the orange/gry one and it comes on with the brakes and with the right turn signal.
what if i only wanted brakes? would i have to connect to the green one from the CHMSL (third brake light)
Old 09-06-2011, 11:09 PM
The brown wire comes on with the running/marker lights. So that would technically be the switch position before the headlights if that matters. The brake lights use the same filament as the turn signals. If you want a brake light only, there is usually a blunt cut wire coming out of the wiring loom under the bed towards the rear somewhere that is labeled CHMSL.
Old 09-07-2011, 12:23 PM
great!
the other way to get brakes only (in this case) would be to have an OR gate and use both turn signals as inputs. however if you had a turn signal with no brakes, then you would still get flashing, but it would go solid as soon as the brakes were applied
edit:
just realized that i could also use the liscence plate lamps as headlight-on signals.
ok
Old 02-25-2014, 06:39 PM
redeye_joe's Avatar
redeye_joe redeye_joe is offline
redeye_joe is starting off with a positive reputation.
Hi, I am trying to wire in a older welding bed and I am finding that the turn signal power runs back through to the brake lights on the oposite side. I have found the wires that run just the brake lights, but because ford has the turn signal combined with the brakes it closes the cuircut back through the brake light when just the blinker is on? Anyone know how else I can run older bed with just turn signal without brakes ?
Old 02-02-2016, 03:37 PM
blonchay123 blonchay123 is offline
blonchay123 is starting off with a positive reputation.
rear wiring harness
hi, I was under my 04 f 350 xl with the 6.0 powerstrke in it and noticed that one of the wires that is apart of the rear lighting harness has six wires running to it and six coming out. of those six there is a green wire that seemed to have an end on it but there are no other corresponding solid green wires going out to the light. everything on the truck works as far as signals and brake lights. I was wondering if that's a chasis ground that needs to be reconnected? thanks
Old 02-02-2016, 04:03 PM
Trophy_23's Avatar
Trophy_23 Trophy_23 is offline
Trophy_23 is gaining momentum as a positive member of FTE.
Quote:
Just a guess but maybe it is for a high mount brake light if you add a canopy?
Old 02-02-2016, 04:34 PM
ligito ligito is offline
ligito is starting off with a positive reputation.
Use a test light, or buzzer to check it. You may need a helper.
Old 02-12-2016, 04:52 PM
David Torch Sasser David Torch Sasser is offline
David Torch Sasser is starting off with a positive reputation.
Please help
Im trying to figure out which wires which on my tail lights wire harness to run some jump wires. My left brake and turn signal arent working. Just need to know whate the brown, black, light green with orange wires are for.
Old 02-12-2016, 07:01 PM
Trophy_23's Avatar
Quote:
Brown is running lights on my 07, I remember that from when I added the dually light bar under my tailgate.
Rewiring Tail Lights Help '78F250351m 1973 - 1979 F-100 & Larger F-Series Trucks 7 03-12-2015 08:33 AM
1966 f100 tail light wiring issue bphirt1 1961 - 1966 F-100 & Larger F-Series Trucks 7 02-26-2015 10:22 AM
Cruise control inop after flatbed install whalebus2112 1987 - 1996 F150 & Larger F-Series Trucks 6 09-07-2014 07:45 PM
79 Tail light wiring harness problem. 273Banjo 1973 - 1979 F-100 & Larger F-Series Trucks 3 05-11-2009 03:14 AM
94 F-250 No tail or trailer running lights pgrant Electrical Systems/Wiring 4 06-09-2004 11:46 PM
Tags
1979, 1986, 2004, 99, brake, bronco, diagram, f250, f350, f550, ford, light, lights, rear, tail, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
