2006 KR F150. The air blows, but not cold. I just had everything checked in regards to pressures, freon, etc., but still only blows ambiant temperatures.
It's possible that you could have a blend door issue. Common problem with most Fords. Run a search on here for blend door and you'll have enough reading material for an entire day.
