Phil's 1979 Ford F250 Build
#46
Awesome thread!
I too have a build thread here somewhere but when I'm going to school 50 miles away from my home and truck I only work on it on weekend nights because I'm hunting during the day. One of the last things to be done with my body is paint the underside of the bed, Its all cleaned up I just need to get the time to properly paint it
#47
Haha! Wasn't trying to call you out. I just wanted to be sure you knew about technique. I put an average of 7 coats on the truck by my username all with a spray can, so I have LOTS of rattle can practice
#49
Its been a while since I've found time to do some work on my truck......this is a mortal sin, and no worries, I have already been punished for it.
Earlier, I had been flushing the radiator and cooling lines to get it all cleaned out, I had left water in there since the last time I was working on the truck. Well, last week Thursday, it was going to dip well below freezing. I had to flush drain the water and add antifreeze to it before it'd crack my block.
Of course I waited to the last second.
Of course it was very cold and 8:00pm at night.
Of course it was the day before my wife had surgery.
All I had to do was drain some water and fill up a radiator with antifreeze. Then run the truck for a while to get it mixed up and circulated. Shouldn't take more than a couple minutes right?
First, I drained the radiator. The stopcock launched out and fell somewhere in the dark. I thought I'd heard it land in my drain pan. So picture this..............picture a man in black shoes, pressed black dress slacks, button-up shirt rolled up fishing in a drain pan filled with radiator fluid for a small stopcock. Did I mention this fluid was below freezing, literally?
I thought I'd found it when I saw something dark at the bottom of the pan with my flashlight, so I went for it. Turns out, it wasn't a stopcock. Just a frozen dead mouse, in my hand. Nice.
I found the stopcock under the truck 10 minutes later. Wasn't even in the drain pan. FAIL.
Got the radiator filled and went to start the truck. Of course, nothing happened, it wouldn't spark. Not even with some starter fluid. Checked it with timing belt, no signal. Tested wires, they all seemed decent. Guessed it could have been the ignition module. I remembered I'd seen one behind my seat in the cab. It had sat there so long the seal had melted into the carpet, had to pry it off the carpet with a screwdriver. Nonetheless, we attached it and tried it out. Sure enough, she fired right up. Success!
5 minutes later, we ran out of fuel and had none setting around. FAIL.
After getting fuel, we let the stuff circulate, packed it up and turned down for the night finally. Almost 2 hours later.
In a nutshell, I played with a dead mouse in fishy smelling liquid, found a part when I actually needed it, and returned home to an angry wife (who would have been much angrier if I had ruined my dress clothes of course). I'm not sure the day was a success or a failure.
#50
Wife's Rule #2191 states that thou shall not go near any project truck or the facility in which such project is being stored wearing any clothing that has been deemed nonperishable by said "wife".
Isn't it weird the places that Permatex ends up other than on your fingers or a rag? (Like hair, crotch or carpeting)
#51
#52
#53
hahahahahaha when i read this i exploded laughing! just today i came home and i was asked why i had "coulk" (rtv to my folks) on the crotch of my pants
#55
hey Guys, I really enjoy reading this post. I have a green/jade 1978 f250 4x4 with the original 400 rebuilt and the 4 speed manual transmission which I started rebuilding 8 years ago. Had to stop while I went back for more schooling and when I returned to my truck, my truck account was empty. My wife found the box of receipts, fortunately she doesn't have a shoe fetish. No, I didn't get off that easy. My truck runs and drives, even had it on the road for a month. Finally had to park it again. So I crank it up on the weekends and drive around the property. I bought the truck in 1980 and it was awesome looking back then. SHE will be again.
#56
#58
#60
Wodges, I sure hope you continue to work on and revive your green beast back to its previous glory!
As for the parts receipts, how could you have let them fallen into your wife's hands?! Critical error! My wife would probably murder me, and I haven't barely begun yet......
Alas, I am also ridiculously **** about documenting the things I've bought and spent money on the truck. Mine is typed, and saved in an excel spreadsheet as "basic_blackjack_strategy.xls", something she'd never dare click on.
WIN.
WIN.
