Power seat switch - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Power seat switch
Old 09-04-2011, 10:46 PM
stewartjwnls stewartjwnls is offline
stewartjwnls is starting off with a positive reputation.
Power seat switch
I have an 03 Exc that has a defective power seat switch on the driver's side. Everything works except for the forward motion position.
Usually, I can repeatedly push the switch to the forward position, and eventually it will work. Alas, no longer.
Is there any chance that the switch is not bad, and I need to check something else out?
If not, can anyone tell me what the part number for this switch is, and do I have to buy this from Ford?
I have found this part on Rock Auto, but am not sure if it is the correct switch.
AIRTEX / WELLS Part # 1S9111 Electrical-Switch & Relay : Seat Switch $71.79
Have not called Ford yet, I'm a little afraid to.
Thanks in advance.
Jim
Old 09-05-2011, 06:55 PM
Update
Never mind. Took the switch apart today and like I suspected, the contacts were corroded.
Took a micro file to them, re-assembled, and now it works again.
Not sure what I might have saved on the new part, but worth it, regardless.
Driver's Side Power Seat Problem - Stumped Biff44 Excursion - King of SUVs 1 04-19-2015 10:58 AM
2010 Power Seat Problem ccecilm2 Escape & Escape Hybrid 2 10-09-2014 06:46 AM
High beam switch not locking on Big-Red-Lariat 2009 - 2014 F150 4 06-22-2014 03:05 PM
Power Seat Troubleshooting dakotajeep 6.0L Power Stroke Diesel 6 02-13-2014 03:22 PM
Power driver seat not working Ryno22980 Explorer, Sport Trac, Mountaineer & Aviator 4 09-14-2009 05:34 AM
Tags
1999, 1s9111, 2002, airtex, electric, electricalswitch, excursion, f250, ford, part, power, relay, seat, switch, wells
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
