All electic goes dead when key to 'start' - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 09-04-2011, 05:39 PM
leeg777 leeg777 is offline
leeg777 is starting off with a positive reputation.
Our '97 Exped has a strange problem. When you turn the key to the start position, you hear a 'click' and all electical power goes off - radio, head lights, dash lights - everything. Turning the key to 'off' then back to run gives all electrical power back except all the radio stations are gone since power was lost to it. Everything looks normal until you try to start the engine again then back to all dead.
The truck had been driven much of the day with no problems, then upon trying to start it again the problem started.
The battery is new and we haven't had any rain recently (with 100+ degree weather and record drought in Texas).
I am assuming the problem is with some relay or something but I have been unable to find any info in my Haynes manual or elsewhere on this forum.
Anyone have this experience or an idea of the cause?
Thanks,
Lee
Cypress, TX
Old 09-04-2011, 06:24 PM
LeeLeadingham LeeLeadingham is offline
LeeLeadingham is starting off with a positive reputation.
IIRC - I had the same problem. Replaced the starter, solenoid on the firewall by the battery, and the starter relay, and my problem was solved.
Hope yours is not as bad.
Old 09-04-2011, 11:55 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
A bad battery cable connection can also be the cause. Check all ends of all the cables for breaks, corrosion, or looseness.
Old 09-05-2011, 01:11 PM
Loose battery cable it was! I never knew that would cause the symptoms I was getting and I assumed (some day I'll learn not to do this) the guy that installed the battery a couple of weeks ago insured the cables were tight.
Thanks for the help!
Confusing Electrical Issue Rottsailor 1997 - 2003 F150 3 11-25-2014 11:25 PM
1980 F100 turn key, won't start then everything dies. Uncle Paul 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 05-22-2014 10:33 AM
I'll be in Anaheim Ca...who's up for a beer? X_Hemi_Guy Excursion - King of SUVs 6 02-21-2009 10:04 PM
Diagnose my dead F150 problem! 89MustangGX 1987 - 1996 F150 & Larger F-Series Trucks 3 02-18-2003 11:02 PM
trys to keep running cypress_303 Ford Inline Six, 200, 250, 4.9L / 300 11 05-03-2002 05:16 AM
Tags
aerostar, dead, ford, key, start, truck, turned
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
