Compession test numbers help to get them up to par.
Guys, I got time and did a copession test on my 48 today.. Should have done this first thing.... Anyways here are the numbers I got for my inline six...
1) 65
2)0 :-(
3)110
4)110 as well
5)65
6)0 :-(
I just added oil to all of them and will let them sit for a day or so... My uncle was asking me if the motor would run one the four and maybe gett compession back in 2,6
Best,
Cody
1) 65
2)0 :-(
3)110
4)110 as well
5)65
6)0 :-(
Best,
Cody
A compression test on an engine that has not run in a while means very little. I would guess 2 and 6 have stuck valves. Stuck rings are another possibility but 0 compression is probably valves. Use a good solvent, seafoam and if you can get it into the valve stems and rings it may help. Sounds like the engine has not run in a while and you're probably better off pulling the head and going through the valves. So then, "what is the lower end like" should be the next question.
The valves can be seen through the spark plug holes. Take a look to see if all your valves are moving. You may be able to soak them with solvent and get them to free up without pulling the head. Be very careful (probably don't try) about trying to push them back down, you can break the head off a valve by pushing off center on a stuck valve.
1) 65
2)0 :-(
3)110
4)110 as well
5)65
6)0 :-(
Best,
Cody
1) 65
2)0 :-(
3)110
4)110 as well
5)65
6)0 :-(
Best,
Cody
1)120
2)still 0
3)135
4)150
5)150
6)and still 0... Happy tht 4 out of the six are up n 100s... Still have to work on 2n6 should I try n start the truck on the four ???
Absolutely not. You'll be filling #2 and #6 with gas, that doesn't get fired off, or if it does will blow back thru the intake, or touch off in the exhaust. It isn't like the valves are going to come free from the rest of the engine running.
I've had engines where running helped everything loosen up and get back to working properly. It definitely wasn't the safest thing, but it worked. The most effective trick I have is to get the engine running, and pour automatic transmission fluid down the carburetor. This puts out a huge amount of white smoke, so don't do this inside. The unburned transmission fluid really helps lubricate the valves and can sometimes get them to un-stick.
If the valve isn't moving at all, I doubt anything but disassembly will free it. If it's moving a little, maybe it could free it up. Depends if it's rusted or just stuck with varnish too.
Seafoam: Lots of youtube videos of folks using it, probably the best instructions - pick a video that matches the mfg instructions the closest.
Where: Orielly, Advanced Auto, AutoZone, Pep Boys, even wal mart and big lots - just about anywhere that sells auto stuff. (wal mart and big lots are less likely... don't know for sure I have seen it there or not).
I too have a compression problem (1 cylinder 45psi, and all cylinders low against spec ~75psi) so am going to do the seafoam thing as well.
Be sure to post your results, if you beat me to application I'm curious to see if yours resolves
I should have clarified, pour a very thin stream of ATF down the carb. You have to rev the engine a bit to keep it from stalling while doing this.
At this point you don't have much to lose. With a flathead, you have no worries of a stuck valve hitting a piston. Your biggest worry is that there is sludge that breaks free and blocks an oil passage. Make sure you have an exhaust system without holes so it isn't so loud you can't hear the engine. Start the engine and listen carefully. Diagnose further from how the engine runs and sounds.
On the straight 6, it's real easy to pull the side covers off and apply whatever you like directly to the lifters, valve stems, etc. and >gently< pry on them to help free them up. If you find the valve chest full of crap, you can get it out rather than recirculating it by running it.
Best,
Cody
slightly OT, but would help the current situation for the OP and I've been curious to see this but can't find it online. Does anyone have a good picture album of a 226 rebuild (I know they are simple simple, little too them, and I have found flat 8 rebuild here and HAMB, but no sexy 6 galleries).
Walle1danman
07-25-2013 06:56 PM
johnson2007
19
03-18-2011 09:14 AM
gwp36530
04-25-2004 01:02 AM
