2003 F250 alternator problems - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-04-2011, 10:41 AM
craigt8 craigt8 is offline
craigt8 is starting off with a positive reputation.
I have a 7.3 diesel and I have been going through alternators. I bought the truck used knowing it needed new battereis and an alternator. When the shop replaced the alternator it was a bad one and they had to put a new one in the next day. It lasted about 18 months, and then went bad. A few weeks before it went bad I got a new cd player in my truck that has a touch screen and dvd player with built-in bluetooth. Basically I have went through 3 alternators in 4 months since I've had the cd player and I dont know what is causing it. I replaced the starter because it was bad, but it seems to still be sluggish on the 1st start of the day and my I had to get jumped off yesterday. Is my cd player the cause? I only have the stock speakers and don't watch DVDs.
Old 09-04-2011, 11:03 AM
Pili's Avatar
Pili Pili is offline
Pili is starting off with a positive reputation.
i seriously doubt the CD player is effecting your charging system. Even though its possible to get bad new parts. 3 alternators in 4 months tells me something else is your issue. The slow starting is because the batteries are low. Do you know if the shop went through the entire charging system or is just replacing parts and sending you out the door?
Old 09-04-2011, 11:21 AM
After the 18 months I had them give me the replacement alternators and have put them in myself. I am not sure if they have gone through the whole charging system to see if there are other problems.
Old 09-04-2011, 11:34 AM
Pili's Avatar
Are you getting the old alt tested before you replace it or are you assuming that is the issue? This thread http://www.ford-trucks.com/forums/10...lternator.html on post 10 has the schematic for the 7.3 charging system. check all the wires for shorts. If you have a multi meter you can check everything out yourself.
Old 09-04-2011, 02:40 PM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
I had bad experience with NAPA rebuild alternator and reading this forum -bad alternators are pretty common. The problem with alternator testing is that bad brushes, or bad regulator can have intermittent problems for long time before giving up and my bad alternator was passing bench test with flying colors, before it die 6 weeks later.
When I had the problem, I wired good tester to the cigarette plug and was observing the voltage during driving. It could jump from 12.8 to 14.3 V in split second, while dash gauge would not move at all.
One of the problem I had on my 7.3 starting was poor connections on ground cables to the engine block. You might want to clean and recheck them.
Old 09-04-2011, 03:04 PM
Rongold's Avatar
Rongold Rongold is offline
Rongold is gaining momentum as a positive member of FTE.
ALTERNATORS GOING BAD
Have someone check both batteries with a newer style conductance tester, not a load tester. A load tester just tests how much current a battery can produce--A conductance tester actually tests how fast a battery can recover from a high current draw. You have to isolate each battery from the other to test them, as they are wired in parallel. Disconnect the cables from both batteries and test them individually. You will probably find that 1 of them is bad, and that is what is killing your alternators.
RON
CD player/steering wheel button questions MBBFord 2004 - 2008 F150 2 11-12-2014 04:14 AM
2006 Ford F350 Super Duty Alternator Problem BGH21 1999 to 2016 Super Duty 4 10-17-2012 06:46 PM
Sync and new MP3 player...?? ddrumman2004 2009 - 2014 F150 6 12-04-2011 06:59 AM
68 F100, Charging problem Maverick68F100 1967 - 1972 F-100 & Larger F-Series Trucks 3 01-14-2006 10:12 AM
My OEM CD player going nuts partsBoy Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 2 03-03-2005 10:43 PM
Tags
2003, 2004, 96, alternator, bad, diesel, duty, f250, ford, issues, problem, problems, super, v10, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
