1948 Ford F5? - Ford Truck Enthusiasts Forums
1948 Ford F5?
Old 09-04-2011, 08:57 AM
Barthog34 Barthog34 is offline
Barthog34 is starting off with a positive reputation.
1948 Ford F5?
Hello All,
I am new to the site and the world of modifying ford trucks, so be gentle!
I have recently picked up a 1948 Ford Farm Truck - it looks to be an F6 maybe. 12,000lbs GVM originally.
I was wanting to put the cab onto something with better running gear to make a daily driver out of it.
Can anyone suggest a suitable chassis to look for?
Thanks in advance,
Bart
Old 09-04-2011, 10:07 AM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
Welcome to FTE, Bart. Any chassis swap is always a challenge to make it look right, and many will discourage doing it. However, most bigger trucks are a standard 34" wide frame, so that's half the battle, lol. Usually it's easier to just swap the driveline to the original chassis, and work out the details such as steering, brakes, gas tank, etc... as progress allows. But a good plan is in order. Others here who have done a swap like this have used '70's F350's... 51dueller being one. A search with his name and "chassis swap" might yield results that will help you. Good luck!
I'm currently doing a chassis swap on an OT vehicle, and I'll say firsthand, it's not easy.
Old 09-04-2011, 10:48 AM
Moe Craig's Avatar
Moe Craig Moe Craig is offline
Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.
Welcome to FTE.... Kiss all your free time goodbye... Between working on the truck and here, everyone is going to think you have a new girlfriend... You can look for a f1 or f2/f3 frames... and unstall an engine/trans/rear end in to make it a DD, depending on what you want for you DD... Putting one on a newer frame with the wider wheel base looks funny... Here some pics of a '48 f3 on a (2500) 3/4 ton frame
Old 09-04-2011, 06:27 PM
youngfordkid's Avatar
youngfordkid youngfordkid is offline
youngfordkid is starting off with a positive reputation.
im currently in the middle of a swap very simmilar to yours. my 51 is a f6 and i found a 49 f1 frame to put it on along with a bed. the swap isnt bad with a frame that works, just a little thought is needed if one wants to use the larger components off a larger truck.
good luck and dont forget to have fun
modesto, california craigslist 1948 F4 for sale mrcman58 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 09-10-2015 10:04 PM
1948 continued Jack1948 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 07-06-2015 09:03 PM
1948 ford f68 ? Cody_1948 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 09-16-2011 02:09 AM
Restoring 1948 Ford F-3. Need as much help as possible SwansonF3 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 02-08-2011 10:39 AM
Where to get door hinges for a 1948 f1? g84t8f1 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 03-22-2010 01:50 PM
Tags
1948, 1949, big, block, brakes, f5, ford, frame, length, model, put, specification, specs, total, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
