Complete Fuel System Failure - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 09-04-2011, 07:45 AM
gwcon's Avatar
gwcon gwcon is offline
gwcon has a great reputation on FTE.gwcon has a great reputation on FTE.gwcon has a great reputation on FTE.gwcon has a great reputation on FTE.gwcon has a great reputation on FTE.
My 08 F350 has suffered a complete fuel system failure. I went into the dealer about two weeks ago with an acceleration and power issue that would occur at different times. I would step on the accelerator and have no power but the RPM's would jump up. Result of that visit was truck in the shop for two days for a replaced low pressure fuel pump. Got the truck back and still had the problem. Went back in and of course the truck would not duplicate the problem with the tech riding in the truck plugged into the PCM. Finally got the tech to experience the problem on my next visit but the truck would still not throw any codes even while the problem was occurring. Dealer said that nothing could be done until a code was thrown up but they would talk to FORD and try to resolve the problem. Bring the truck home again with the problem still not fixed. Got the "drive to clean exhaust" message on the truck when I entered my driveway(had never gotten that message before in three years of ownership). Took the truck out to the highway the next day to honor the message's wishes and after getting up to 70mph the truck burped a large amount of smoke, shuddered and went into the complete shut down mode. I had no brakes, power steering or any control of the truck at the last portion of the shut down. Glad I wasn't hooked up to my 30' trailer coming to an intersection at the time. Truck has been at the dealer for a week and a half now and they told me the fuel system has suffered complete destruction.They are replacing the high pressure fuel pump, injectors, fuel filters and everything else that has to do with the fuel system and still had to break down more of the engine to make sure nothing else was damaged.
Sorry to be long winded but its amazing to me that FORD did not do some more investigating when the problem was small and cheap.
Old 09-04-2011, 08:26 AM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Wow, So your fuel pressure reading were still ok I guess even though you were having symptoms.
Old 09-04-2011, 08:51 AM
gwcon's Avatar
senix,
The first time there must have been a slight variation because they replaced the low pressure pump but after that yes, the pressure was normal. Tech had it hooked up to his computer for a thirty minute drive with no codes at all even while it was having the problems.
Old 09-04-2011, 02:34 PM
Brandon D's Avatar
Brandon D Brandon D is offline
Lead Foot User
Brandon D is gaining momentum as a positive member of FTE.Brandon D is gaining momentum as a positive member of FTE.
Sorry to hear about the headache, how many miles on that truck now GWCON?? I understand what you're saying that the dealership should have caught it but they won't start replacing parts at their expense until they have a good reason. The good news is that you should still be under warranty and aside from losing your truck for a couple weeks you hopefully won't be out anything else. Good Luck
Old 09-04-2011, 02:51 PM
gwcon's Avatar
Thanks Brandon B. There are 34,000 miles on the truck however, its been over three years so my 3yr 36,000 is gone but I purchased the extended warranty and this damage should be covered under the 100,000 year powertrain warranty. This is why I have more than one truck. I can't run my business with my wife's car and definately could not afford to lose two weeks. Although it is covered, well I hope they don't want to fight over it, it is still a big PIA.
Old 09-04-2011, 03:06 PM
Brandon D's Avatar
Lead Foot User
Quote:
Originally Posted by gwcon View Post
Thanks Brandon D. There are 34,000 miles on the truck however, its been over three years so my 3yr 36,000 is gone but I purchased the extended warranty and this damage should be covered under the 100,000 year powertrain warranty. This is why I have more than one truck. I can't run my business with my wife's car and definately could not afford to lose two weeks. Although it is covered, well I hope they don't want to fight over it, it is still a big PIA.
That's a major failure for the low mileage, they better cover it or I'd be making some phone calls. Best of luck.
Old 09-04-2011, 03:33 PM
gwcon's Avatar
I agree , I will be and thanks.
Old 09-04-2011, 04:38 PM
StanleyZ's Avatar
StanleyZ StanleyZ is offline
StanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to behold
I thought the 11B23 flash was going to prevent total failures of the fuel system by shutting down the engine before that could happen. Did you have that re-flash? just wondering.
Old 09-04-2011, 05:56 PM
senix's Avatar
Well it should have been caught if you had the newest flash done. Or at least I think it should have. They will cover it since you had in the shop to begin with and they were trying to figure it out when it happened.
Old 09-05-2011, 07:37 AM
gwcon's Avatar
Had the latest flash when the small problems began. After the tech actually experienced the problem while driving the truck he reflashed it again with a PCM upgrade that he said they had only had for a few days.
The truck shut down like it was supposed to but you can only stop from a speed of 70mph so fast.
Old 09-05-2011, 02:57 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
....This is why I have more than one truck. I can't run my business with my wife's car and definately could not afford to lose two weeks.
For the longest time, I kept wondering why you had 3 of the same trucks...this definitely explains it.
Best of luck to you on the repair!
Old 09-05-2011, 03:05 PM
gwcon's Avatar
That's the main reason but I'm also probably a couple lug nuts short of a tight tire. LOL
Thanks for the well wishes.
Old 09-05-2011, 06:42 PM
senix's Avatar
Keep us posted!
Old 09-05-2011, 08:19 PM
gwcon's Avatar
Will do. Should hear something by Tuesday(I would hope anyways.) Got the backup hooked up and ready to go for tomorrow. Gotta get it while you can.
Old 09-08-2011, 10:46 AM
gwcon's Avatar
Brief update for anyone interested:
Still have not gotten the truck back yet. However, they drove it this AM so it is back together again. Will let you all know what exactly happened when I find out for sure but it seems the high pressure fuel pump failed(which was the tech's guess way back when the problem was small) that caused an overfueling condition which burned up injectors and caused other problems.
P2284 after oil cooler work, Ford 6.0 hawkco66 6.0L Power Stroke Diesel 23 10-23-2016 08:49 PM
IPR Failure jsm180 6.0L Power Stroke Diesel 4 08-07-2016 04:49 PM
33,500 Trouble Free Miles Until.... gwcon 6.7L Power Stroke Diesel 46 06-05-2016 05:43 AM
Intermittent problem Skyhawk Greg 1994.5 - 1997 7.3L Power Stroke Diesel 73 09-15-2014 10:29 AM
6.0L No Start Mystery dpassarella 6.0L Power Stroke Diesel 17 03-30-2014 07:55 PM
Tags
2006, 2008, 64, covered, f350, failure, ford, fuel, powertrain, pump, shut, start, system, truck, trucks, warranty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
