Complete Fuel System Failure - Page 3 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
  #31
Old 01-22-2014, 06:59 PM
winklershop winklershop is offline
winklershop is starting off with a positive reputation.
so hpfp, all 8 injectors, all fuel lines can only be installed once? they cant be reused once tightened? what about the fuel cooler, low pressure pump, HFCM, both fuel filters and bases, what about all the glitter in the fuel that returned to the tank. i dont really understand their PCM update either...it was changed to shut the engine down immediatly so future damage wouldnt be caused, but when your going 50 down the road and have a stick shift the engine still is turning pumping all the fuel around until you come to a stop.
  #32
Old 01-22-2014, 07:12 PM
Steelhant Steelhant is offline
Steelhant is starting off with a positive reputation.
I'm not sure about the other parts, but when they did mine, fuel tank was cleaned too, I'm not a mechanic, But I watched very closely when they did my repairs...Also the cab had to come off for the repairs to be done...
Hope it works out for you
  #33
Old 01-23-2014, 09:47 AM
what about they can only be tightened once?
  #34
Old 01-23-2014, 02:38 PM
9228.bobcat's Avatar
9228.bobcat 9228.bobcat is offline
9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.
Quote:
Only once. All the lines to the hpfp, fuel rail to injectors, the can only be used once. If you try to reuse them they will leak fuel, fill your crank case full of fuel and it will take off on you and blow your engine.
  #35
Old 01-24-2014, 05:05 PM
yeah that makes sense, i just have to do it now. i wonder how much of the other stuff i can figure out how to flush and get clean again with out having to replace everything.....oh and i have now a 2nd 6.4 in my shop with the same problem....@!#%@#$@#@#$@#%@
P2284 after oil cooler work, Ford 6.0 hawkco66 6.0L Power Stroke Diesel 23 10-23-2016 09:49 PM
IPR Failure jsm180 6.0L Power Stroke Diesel 4 08-07-2016 05:49 PM
33,500 Trouble Free Miles Until.... gwcon 6.7L Power Stroke Diesel 46 06-05-2016 06:43 AM
Intermittent problem Skyhawk Greg 1994.5 - 1997 7.3L Power Stroke Diesel 73 09-15-2014 11:29 AM
Complete Transmission Failure at 53,000 miles: Caused by Flush. Nick O'Teen 2004 - 2008 F150 21 09-08-2007 01:25 AM
Tags
2006, 2008, 64, covered, f350, failure, ford, fuel, powertrain, pump, shut, start, system, truck, trucks, warranty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
