Complete Fuel System Failure - Page 2 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 09-08-2011, 11:03 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Maybe the VCV in the fuel pump was putting out too much fuel. Will be interested too see what the root cause was.
Old 09-08-2011, 08:22 PM
gwcon's Avatar
gwcon gwcon is offline
gwcon has a great reputation on FTE.gwcon has a great reputation on FTE.gwcon has a great reputation on FTE.gwcon has a great reputation on FTE.gwcon has a great reputation on FTE.
Picking the truck up tomorrow. Should be interesting but I think you are correct Scott. I think the VCV stuck open and let the fuel flow big time. The truck actually sped up for a brief moment after I let off the pedal when I knew something was bad wrong. I will update as soon as I know.
Old 09-10-2011, 08:39 AM
gwcon's Avatar
Picked up the truck and it seems to be running great. They did not have my paperwork ready yet so I don't have anything to copy verbatim however, I did get a chance to talk with my tech for a while to discuss the extent of the damage and repairs.
Basically the high pressure fuel pump came apart internally. This in turn caused an overfueling condition that caused extreme heating that destroyed all eight injectors and 5 glow plugs. The dealer is supposed to mail me the paperwork so if there are any other points to this failure I will post an update. Other than being a PITA I have a brand new fuel system at 35K and got my fuel filters and oil changed for free. I am towing my 30' rig with her on Monday so that will definately be a true test of the repairs.
Old 09-10-2011, 09:13 AM
senix's Avatar
Hope it all is fine.
Old 09-10-2011, 12:14 PM
Ian123's Avatar
Ian123 Ian123 is offline
Ian123 has a very good reputation on FTE.Ian123 has a very good reputation on FTE.Ian123 has a very good reputation on FTE.
Glad you got it taken care of. Before I bought my truck I was $1000 away from buying an 08 6.4 where the oasis stated it just had the low pressure fuel pump replaced. I wonder if this kind of repair you just had was in its near future.
EDIT: Do you know why the HPFP came apart? I've heard rust (from water in the fuel) is usually the way they fail
Old 02-23-2012, 09:09 PM
snowbound152 snowbound152 is offline
snowbound152 is starting off with a positive reputation.
wow, my engine light came on in October, was losing power and such, dropped it off at the dealers to get it checked out, they told me that there was metal filings in the system and they
needed my permission to find the root problem.
they told me that it would cost me 15 to 20 grand to repair, and that ford canada was not going to warranty it.
here in canada we have an organization called CAM-VAP, they are an impartial 3rd party arbitration firm ( i guess). ( the back of your owners manual) .
i have 149000 kilometers on my 08 350.
anyway we had a hearing, i had taken my pump from the dealer after it was removed because ford canada said that there was rust , and that i must have used bad fuel, that pissed me off. so i have the pump, and no rust on it. i take it with me to the hearing, ford says must be the pump and water, then it was, i didnt change my fuel filter enough. to make a long story short.......my truck goes into the shop today for repairs... at NO cost to me, the entire fuel system replaced....sweet
Old 02-23-2012, 09:40 PM
ljutic ss's Avatar
ljutic ss ljutic ss is offline
ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.
15-20 grand, thats twice the cost for a complete fuel system in America. Must have several hundred dollar an hour rates up there.
Old 02-24-2012, 05:12 AM
senix's Avatar
Good for you! I think they were trying to get over on you with the typical cause and you called their bluff.
Old 02-24-2012, 10:00 AM
yeah, rails, injectors, all pumps, separator........ everything, and the labor cost here is 209 an hour at the dealer here.......man o man
Old 02-24-2012, 08:15 PM
Steelhant Steelhant is offline
Steelhant is starting off with a positive reputation.
Well just over 60,000 miles and I'm on my second pump and injectors...so far no cost to me other than not having a vehicle for 44 days in a year...to be honest the 6.4 is junk. and Ford knows..Engine was making oil and smoking to no end..both times they changed a bunch of parts....bed full.... EPA should drive behind one.......drivers behind you choke it's that bad...
Hope they get yours fixed..
Old 01-22-2014, 01:28 PM
winklershop winklershop is offline
winklershop is starting off with a positive reputation.
what did you guys find out? i am having the same problem.
Old 01-22-2014, 03:44 PM
To be very honest ..sell it... I went through 4 fuel pumps, oil coolers under intake....a mess...I ended up giving it back to ford...6.4 uses fuel to clean , exhaust...When it goes into regen the fuel system dumps extra fuel into cylinders that leak past the rings, Oil level goes up and then the smoke....I mean smoke...
Everyone I know who had one had the same problem...brutal design...great truck, junk motor... FORD KNOWS IT TOO....
To be honest, I bought a 2013 and it great so far. ...Not a Chevy or Dodge fan..
Fuel mileage is way up from 12-13- ...2013 gets 18- 19 mpg tells you something
  #28
Old 01-22-2014, 03:54 PM
i was driving the truck, heard a pop, and then engine shut off. got it back to the shop, the only codes was P0088 fuel pressure too high, and then a P0087 fuel pressure too low, and then engine shut off...
  #29
Old 01-22-2014, 05:37 PM
i took the HPFP and found rust splotching all over, rust started the galling process on the end of the pump, there is some kind of mechanical pump that feeds the three pistons of the high pressure side. the mechanical pump portion was galling like crazy, so now this fine particulate matter is through the whole system. i have to get the truck runnning to at least sell it. i would have to take apart and clean all the injectors (are they even servicable? i know the 6.0 L injectors are doable) and the fuel lines would have to be flushed, fuel cooler, low pressure electric pump, fuel filters.
  #30
Old 01-22-2014, 05:54 PM
Everytime Ford changed my fuel pump.... 4 times....injecters and fuel lines had to be replaced. Can only be tightened once....
P2284 after oil cooler work, Ford 6.0 hawkco66 6.0L Power Stroke Diesel 23 10-23-2016 08:49 PM
IPR Failure jsm180 6.0L Power Stroke Diesel 4 08-07-2016 04:49 PM
33,500 Trouble Free Miles Until.... gwcon 6.7L Power Stroke Diesel 46 06-05-2016 05:43 AM
Intermittent problem Skyhawk Greg 1994.5 - 1997 7.3L Power Stroke Diesel 73 09-15-2014 10:29 AM
6.0L No Start Mystery dpassarella 6.0L Power Stroke Diesel 17 03-30-2014 07:55 PM
Tags
2006, 2008, 64, covered, f350, failure, ford, fuel, powertrain, pump, shut, start, system, truck, trucks, warranty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
