Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 09-04-2011, 05:13 AM
billhutch billhutch is offline
Garage is empty, add now
billhutch is starting off with a positive reputation.
99 ZX2 A/C
Cold air gradually (4-5 months) declined to now blowing warm air. Compressor kicking on and off within seconds. Don't know if low on R-134 would cause comp. to do that. Have a gage but not sure where low side is and 50/50 ain't good odds. Any suggestions?
  #2 (permalink)
Old 01-28-2012, 06:57 PM
whitefordexplorer's Avatar
whitefordexplorer whitefordexplorer is offline
1991 Ford Explorer
My Garage
whitefordexplorer is gaining momentum as a positive member of FTE.whitefordexplorer is gaining momentum as a positive member of FTE.
cooksmobile@yahoo.com MUSCLEDRIFTER
this may be a bit late, but the low side is after the evaporator, follow the lines from the compressor, if one heads to the condenser (radiator looking thing in front of car) then thats the high side... you may want to have your low pressure switch checked before you add refrigerant, because too much will cause it to blow warm. also if you can, have a dye placed in the system if you do add fluid so you may find a leak later.
__________________
-Landon
My wife said if i didnt stop spending money on my truck and not her, she would leave..... My new girlfriend loves my truck!
if it has t**ies, tires or tools, it has my full attention.
  #3 (permalink)
Old 01-30-2012, 07:48 PM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
Hi side and lo side service fittings are different sizes. Low pressure WILL cause the compressor to cycle frequently. (fail safe pre-caution)
__________________
Speed is a question of money. How fast "CAN" you go?
Tags
1999, 2003, 99, ac, high, low, pressure, side, switch, zx2
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
