1985 f150 fuel tank selector valve
i have a 85 f150 4wd with dual tanks. the truck is a factory 351w 4bbl carb truck. it sat for @5 years with a blown engine. recently rebuilt another 351w and put it in. had to replace both gas tanks due to trash in tanks. could not get fuel to the engine and figured out the selector valve was bad. bypassed it and truck started up.my question is will the universal one wire valve work on my truck? it has a 2 wire connector and it had the plastic fuel lines like a fuel injected truck would have. why would this be on a carb engine?
They went to those type lines, probably because of assembly line speed. The line is made up off the line, and then the line worker just plugs it in and that's it, unlike having to fiddle with a hose clamp. But that does not mean you cannot convert yours over. I have seen plenty of these plastic lines cut off, and then just slipped over a barb with a small hose clamp, I have done it myself, and it seems to work. Sometimes you need to get a heat gun to soften the line a little bit.
If the universal valve has enough ports, and the logic is correct(power to the valve will be one tank, no power will be the other tank) it should work.
i have a 85 f150 4wd with dual tanks. the truck is a factory 351w 4bbl carb truck. it sat for @5 years with a blown engine. recently rebuilt another 351w and put it in. had to replace both gas tanks due to trash in tanks. could not get fuel to the engine and figured out the selector valve was bad ( so, what else is new?!), bypassed it and truck started.
There are two possibles: E5TZ-9189-A -3 ports ~ Marked E57B-9H271-AA // E5TZ-9189-B -6 ports ~ Marked E57B-9H271-BA or E67B-9H271-AA.
If based on the 25 years you said you've had no problems (which I assume means you bought it used), how many of these valves do you think were replaced before you bought it? 1, 2 or ?
One a the first part numbers I typed on FTE was E5TZ-9189-B. I had no '80/89 truck parts catalog back then (11/2006), but didn't need it then and even though I have it now, I still don't need it, because...
The OP said he needed the 6 ported valve and had I memorized the part number decades ago. I passed out mega-dozens of the little charmers to mechanics (for C/P & 1863 RO's), because it was a POS!
I was speaking with Ed Olson on the "Ameche" awhile back (PartsGuyEd.com). We were talking about certain notorious POS Ford parts. When he mentioned the 6 porter, I reeled off E5TZ-9189-B!
He laughed and said...it's an EZ number to remember, considering...
Bill, I bought the truck in 1994 with around 85,000 miles, it now has 119,827 miles. Truck was originally owned by Delmar stables in Suffolk VA, I am the third owner. It has been a tow vehicle it's entire life. When I bought it the front tank had a seam leak and the rear one a bad fuel pump. Loads of fun, every parts store told me I couldn't have electric pumps unless it was fuel injected.
Just use the wire that is hot with the switch in the front tank position.
See post 4
so I have a fuel selector valve I bought that looks very similar to the one on my truck, but the new one just has a post with a nut on it and my current one has a two prong connection. Could I get by with hooking up the power to the post and screwing the other wire to the frame. Please help.here is the part I have. https://www.google.com/aclk?sa=l&ai=DChcSEwijnpLLh5LOAhVGYH4KHV1BDHUYABAP &sig=AOD64_3yGSnmE9Cw90Bm-G47H06ysHHcSQ&adurl=&ctype=5&q=&ved=0ahUKEwj-yJDLh5LOAhUSS2MKHYwnC4oQqCsIeQ
so I have a fuel selector valve I bought that looks very similar to the one on my truck, but the new one just has a post with a nut on it and my current one has a two prong connection. Could I get by with hooking up the power to the post and screwing the other wire to the frame. Please help.here is the part I have. https://www.google.com/aclk?sa=l&ai=...HYwnC4oQqCsIeQ
Just use the Hot wire , you don't need to do anything with the ground wire.
Supercab
07-13-2023 10:40 PM
dieselburner
07-11-2017 11:45 PM
bullnose1985
09-22-2015 09:41 PM
NeverFinished
08-06-2013 11:10 PM
guitar333
07-10-2004 09:14 AM
