Gravel Pan - Ford Truck Enthusiasts Forums
Gravel Pan
Old 09-03-2011, 10:18 PM
1oldtimer's Avatar
1oldtimer 1oldtimer is offline
1oldtimer is gaining momentum as a positive member of FTE.
Gravel Pan
More set backs and lazyness...............but made some headway. I found another gravel pan as mine was FULL of filler, modified it to fit the trans coolers. Also gave up on finding rust free, straight air deflector panels and bought repo ones....of course they needed some work to fit/look right. I also got the headers back from the coater. More to come..........
before
new to me
I had to move the inner supports in a little and make some notches for the cooler lines.
Old 09-03-2011, 11:05 PM
Dano78's Avatar
Dano78 Dano78 is offline
Dano78 has a good reputation on FTE.Dano78 has a good reputation on FTE.Dano78 has a good reputation on FTE.
Very nice clean job! Looks really good.
Old 10-03-2011, 02:07 AM
1oldtimer's Avatar
I bought a new paint gun as my hf gun made more work then helped. Hopefully more pics to come next weekend.
Old 10-15-2011, 05:43 PM
1oldtimer's Avatar
Well I had company last weekend so I shot some primer sealer and paint on it today. Hopefully it will be in this week, then I can paint the air deflectors, then shoot the grill and put it back together to fire up the motor.
What a difference a good quality gun makes
maybe I should start a rebuild thread.......
Out with the old in with the new excursion gets some new toys BuiltFordTough! Excursion - King of SUVs 32 08-02-2013 04:17 PM
Look what I did at work today... ReBilld 1994.5 - 1997 7.3L Power Stroke Diesel 51 07-14-2012 07:39 PM
Bored. So I took some pics. hammerhead90 1987 - 1996 F150 & Larger F-Series Trucks 32 08-28-2011 01:40 AM
53-56 f100 column repair 1oldtimer 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 09-05-2010 08:45 PM
New Wheels and Tires ekbearly Excursion - King of SUVs 7 07-23-2010 07:50 PM
Tags
1949, 1956, f100, ford, gravel, pan, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
