Thoughts on CORDED 1/2" drive impacts? - Ford Truck Enthusiasts Forums
Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Old 09-03-2011, 09:05 PM
powerstroker100 powerstroker100 is offline
powerstroker100 has a good reputation on FTE.powerstroker100 has a good reputation on FTE.powerstroker100 has a good reputation on FTE.
I just started doing mobile mechanic work as a side job, I've used a corded impact once before putting a transfer case yoke back on thought it was neat, that was 2 years ago.
now that im working outside of a shop im thinking my best friend for taking wheels off quickly and doing whatever else would be a corded 1/2" drive impact and a extension cord?
please share your thoughts whether good or bad i was thinking about buying the dewalt 1/2" or kobalt 1/2" drive from lowes dewalt is around 179 and kobalt is around $150 I am spoiled by my ingersol pneumatic tools but cant bring a compressor everywhere I go, this corded tool option seems to be much easier
they both say they create around 350 pounds of torque
Old 09-03-2011, 11:14 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
I would look into either an engine driven compressor or a cordless impact. I used a Snap-On cordless impact for a while that was quite nice.
Old 09-04-2011, 12:00 AM
engine driven compressors out of my price range, I dont think a cordless impact will have as much torque as a corded one
Old 09-04-2011, 12:08 AM
ooh edit, this actually catches my eye
Makita BTW450Z 18V LXT 1/2 in. Impact Wrench (Tool Only)-BTW450Z at The Home Depot
because I already have other makita tools of this model group so I have the nice batteries and charger, think I'm going to buy it this coming weeks any opinions? I wonder how true that 325 torque number is
Old 09-04-2011, 07:37 AM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
I've used a Porter Cable corded impact wrench to drive lag bolts all day sometimes in my carpentry work.
But the 6626 is only rated at 265 foot pounds.
It is solidly built and does it without a hiccup.
A battery tool wouldn't last 10 minutes running continuously, but you have a different situation.
Re: the Makita 450Z. The worst that can happen is that it fails and you have to return it.
Give it a try, sounds ideal for you!
Old 09-04-2011, 08:22 AM
Sterling Archer's Avatar
Sterling Archer Sterling Archer is offline
Sterling Archer has a very good reputation on FTE.Sterling Archer has a very good reputation on FTE.Sterling Archer has a very good reputation on FTE.
I've got a Milwaukee corded 1/2 impact wrench. It supposedly puts out somewhere around 300 lbs of torque. In reality...I wind up using a breaker bar to get anything loose that's in that ballpark. For your intended use (lug nuts), it would be perfect though. That thing really makes rotating a set of tires a quick/easy job. I've gotten a lot of use from it over the years (I got it as a gift six years ago).
If you go with a battery powered impact wrench, I'd pick up an extra battery. Just my $.02.
Old 09-04-2011, 09:07 AM
wdfp wdfp is offline
wdfp is starting off with a positive reputation.
I have a dewalt 18V 1/2" cordless impact wrench and it does lug nuts just fine! Unless they are considerably overtightened its no problem to spin them right off. Got mine for about 200 probably because they are NiCad batteries..
Its a big wrench and works well..
Old 09-04-2011, 12:38 PM
Ford_Six's Avatar
I recently picked up a used engine driven compressor for $325, and have seen quite a few others go in the $200-$500 range.
Old 09-04-2011, 02:28 PM
thanks for all the responses guys!
I'm going to hunt on craigslist for a engine driven compressor for a bit, since I have already so many air tools it would be nice to bring them all around.
If I cannot find one in my price range I think I'm going to buy the cordless makita one I'll keep you all posted!
Old 09-04-2011, 08:57 PM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
I have a Mac air impact, and currently a harbor Freight corded impact. Even the Mac doesn't break 300 foot pound loose, needs a kick start, IE breaker bar. (It is rated for 280 or 350, don't remember, bought it new about 20 year ago)However, the convenience of just grabbing an extension cord and working vs having to drag the air compressor to the place I need to work is a big plus. Not everything makes it to the shop door to be worked on. For portable, and with a good enough inverter, I think it wold work fine. I got the HF impact just to see how much it would be worth to me, and once I can't get it replaced under warranty, I will be looking to upgrade. It has been well worth it.
Old 09-05-2011, 12:42 AM
that was my original thought, it would be so much easier to just plug in a cord rather than air up the compressor, I have a generator to carry too, but then saw the cordless impact and since I already have batteries im thinking thats the way to go, looked on CL today for a gas driven compressor and dont want to spend as much as people are asking
Old 09-05-2011, 03:07 PM
shorebird's Avatar
shorebird shorebird is offline
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
I have a 18" long Snap-on " breaker bar and sets of " Deep well sockets in both SAE and Metric sizes.
I also have a 2' cheater pipe for extra leverage.
If you add my mass to the end of the lever there is little I can not loosen.
I have no idea of the actual amount of foot pounds I can apply but I am certain that it is well over 500'#.
Once the lug nuts are loose a 4-way does the trick.
The breaker bar I got for $5 at a pawn shop.
The cheater pipe was free.
The socket sets I bought at Sears on a Black Friday for $20 a set.
Total with tax is less than $50.
No dead batteries. Works in a pouring rain.
Old 09-05-2011, 05:16 PM
very good way to approach this, I think im just trying to spoil myself with a new tool haha
Old 11-23-2011, 10:56 AM
monckywrench monckywrench is offline
monckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to behold
I use manual tools to break torque then my Milwaukee 28V for removal and installation. It's fast and great for junkyard work. An inverter will feed the Milwaukee charger nicely for mobile work.
No cords, no hoses, no problem, and I've abused Milwaukee 28V tools (grinder, Sawzall, impact, drill, circular saw) for several years with great results. They paid for themselves long ago.
Old 12-28-2011, 09:12 PM
lxlmariuslxl's Avatar
lxlmariuslxl lxlmariuslxl is offline
lxlmariuslxl is starting off with a positive reputation.
Older thread but thought I would share my input. I have the dewalt 1/2 corded impact works good for removing lug nuts but I always go back and check the lugs afterwords when installing, doesnt seem to tighten up as well as it loosens. But as said before beats putting out the air compressor. I really want the snap on cordless impact....when I get the cash extra.
Dash Cam Power Cable tracyclifton 6.7L Power Stroke Diesel 14 01-20-2016 10:44 AM
Block heater tips Tugly 1999 - 2003 7.3L Power Stroke Diesel 70 01-06-2016 10:13 PM
Don't assume your block heater works! / How to test your block heater FarmingF250 1999 - 2003 7.3L Power Stroke Diesel 11 01-04-2016 08:29 PM
advice on impact wrenches? One Sock Garage & Workshop 29 04-24-2014 03:24 PM
Cordless Impact Wrench? spc Garage & Workshop 17 07-06-2005 04:36 PM
Tags
12, corded, cummings, drive, fort, get, impact, lug, pawn, set, shop, socket, worth, wrench
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
