Dash Bezel silver trim how to - Page 2 - Ford Truck Enthusiasts Forums
Old 09-04-2011, 06:33 PM
nothercrash's Avatar
nothercrash nothercrash is offline
nothercrash is starting off with a positive reputation.
I did this around a year ago, but couldn't find a paint pen, and so went with one of those little jars of hobby paint, and a cue-tip. It worked, but it wasn't perfect, this looks GREAT!
But hey, don't hate on Michael's! I've gone there more times as a last resort to find that one weird thing I can't find anywhere else, with generally great results! Thick sheets of cork for custom gaskets, this paint and others, plastic glues and fillers. And tell em you teach kindergarten and they give you a discount! Haha, but no joke! Sure it's no home depot, not a place you go to hang out on a rainy day, but it's come through for me before!
Anyway though, nice work again, and these markers, or the little hobby paints are a great way to really add some snap to your interior. I've used chrome, copper, black, and mixed some to make a green I like.
AleX
Old 09-04-2011, 06:45 PM
MiddleNameMUD's Avatar
MiddleNameMUD MiddleNameMUD is offline
MiddleNameMUD is starting off with a positive reputation.
I did mine with the same paint pen a lil while ago, but I don't know if it was my pen or the bezel but I should have did it backwards. The paint dries fast, I found that running the small lines "inset the bezel" kind of damaged the tip so I couldn't get a real smooth line on the wider lip. But all in all the closest product to use, turned out way better than I anticipated.
Nice work on yours!!
Old 09-04-2011, 06:50 PM
NBC-Steve's Avatar
NBC-Steve NBC-Steve is offline
NBC-Steve is a splendid one to beholdNBC-Steve is a splendid one to beholdNBC-Steve is a splendid one to beholdNBC-Steve is a splendid one to beholdNBC-Steve is a splendid one to beholdNBC-Steve is a splendid one to behold
That's a great idea! I was just thinking that I was going to have to replace ALL of my dash trim to match a new dash bezel. (Old one is cracked.) Now I know I can fix the original Lariat trim!
Quote:
tip: to save embarrassment at "Michaels", just take the wife and go in like you are doing so under extreme protest ... works ever time
I have a wife and FOUR daughters. By now I'm almost numb going to Michaels.
Thanks for the valuable tip and photos (I just love photos!) co425!
Old 09-05-2011, 03:30 PM
BIGT94z's Avatar
BIGT94z BIGT94z is offline
BIGT94z is starting off with a positive reputation.
that turned out great man!
Old 09-05-2011, 05:09 PM
Blown 331's Avatar
Blown 331 Blown 331 is offline
Blown 331 is gaining momentum as a positive member of FTE.
Great job. I'll have to keep this in mind next time I'm at Michaels. lol. Seriously though, I think I'm gonna give that a try. I've got a junk bezel to practice on just incase.
Old 09-05-2011, 06:39 PM
whiteisright whiteisright is offline
whiteisright is starting off with a positive reputation.
anyone put an aftermarket stereo deck in the stock spot? i just took out an old pioneer tape deck out of the stock spot but obviously its going to need some trimming to get a cd deck to fit
Old 09-06-2011, 11:02 AM
toymobile toymobile is offline
toymobile is starting off with a positive reputation.
NOS bezle, I went to Ford dealer closin in Alma GA. in April last year bought all NOS they had I've got 2 dash bezels that I remember(raining now) stored in my motor home one radio delet , just food to feed on Thanks Johnny
Old 09-06-2011, 03:15 PM
White, yes I've done it, and there's actually a kind of tricky, but GREAT (once the work is done) way to do it.
I got a Sony radio/cd/Ipod unit for around 100$, and it was basically the same size as a stock unit, but around twice as deep (front to back). This obviously meant I had to do something about the metal mounts that hold the heater control unit, and the old radio, since they sit facing front, flush with the back of the old unit (meaning the new unit only fits about halfway in). What I did, is just cut them off at their bases, bend them back at 90* so they now sit flush with the TOP of the new radio box, and I drilled one hole in each metal face, and tack welded 2 bolts to the top of the radio box (just the metal shell, do NOT weld with radio nearby!), fit those bolts through the holes in the bent metal pieces, couple nuts, and it works GREAT! You could just as easily use zip ties or something to hold it in, if you don't wanna weld.
Lemme know if you don't get any of that..... AleX
Old 09-06-2011, 06:57 PM
co425's Avatar
co425 co425 is offline
co425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to all
Finally got a min to get the bezel reinstalled. She looks much better with the non working radio out of there.
Old 09-06-2011, 07:19 PM
AK FORD GUY's Avatar
AK FORD GUY AK FORD GUY is offline
AK FORD GUY is gaining momentum as a positive member of FTE.AK FORD GUY is gaining momentum as a positive member of FTE.
co425 - Man that looks sharp. Good job.
Old 09-06-2011, 07:33 PM
turbohunter's Avatar
turbohunter turbohunter is online now
turbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant future
Sweetness!!
Old 09-06-2011, 10:27 PM
grinnergetter's Avatar
grinnergetter grinnergetter is offline
grinnergetter has a good reputation on FTE.grinnergetter has a good reputation on FTE.
Is that a manual choke **** left of the column? If so where can I find one like that?
  #28
Old 09-07-2011, 07:47 AM
co425's Avatar
Quote:
Yes it's a manual choke. It's from Edelbrock. There about $20.00 from summit.
  #29
Old 09-07-2011, 08:18 AM
POPAJON POPAJON is offline
POPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud of
Nice job!!! another hint to go in my tips book. John
  #30
Old 09-08-2011, 01:12 AM
dont think any of that applies to me. the tape deck that was in it was full size, nothing was in the way. i think i have some cutting to do, i also need a new bezel because theres only 2 screws that hold it on, all the other screws broke through.
also, can someone tell me what the blue wire with red stripe is for? you can see it cut and stripped in the picture.
Headliner on the cheap. co425 1973 - 1979 F-100 & Larger F-Series Trucks 78 06-08-2016 04:12 AM
70's roll bar upgrade co425 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-17-2015 08:05 AM
Mounting a Saginaw box on a highboy co425 1973 - 1979 F-100 & Larger F-Series Trucks 19 09-22-2014 03:09 PM
Definition MALL CRAWLER! co425 1973 - 1979 F-100 & Larger F-Series Trucks 5 10-11-2012 12:54 AM
Update on Benchwork steering conversion co425 1973 - 1979 F-100 & Larger F-Series Trucks 13 10-04-2012 04:59 PM
Tags
150, 1999, 4wd, 79, bezel, dash, escape, expedition, f150, f250, ford, pictures, remove, silver, trim, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
