1993 Ford F-150 Headlight Removal / Install w/PICS - Ford Truck Enthusiasts Forums
Old 09-03-2011, 01:12 PM
DEMIGOD's Avatar
DEMIGOD DEMIGOD is offline
DEMIGOD is starting off with a positive reputation.
Hello troops,
I decided to contribute to the forum by doing a some what half *** write up on removing and installing replacement headlights. Installation was not really all that difficult, however I can not for the life of me figure out why Ford even entertained this type of mounting / housing for forward illumination needs. Anywho....here we go.
Purchased a new set of replacement lights off eBay, from seller : nationalautopart for 38.27 shipped....really good price in my opinion and the parts are good quality!
Here is a pic of the truck at the start of the swap...nasty and shows trucks age
Identify two screws on top of bezel and remove
Remove single 11mm bolt from washer resivoir, unplug harness and place entire resvoir to the side
Now you have some room to work in there......
****Unsure if this forum allows huge pic heavy single posts, so will continue by way of reply button.
Old 09-03-2011, 01:19 PM
DEMIGOD's Avatar
Identify locations of nuts that are holding turn signal lense in place....both are 11mm if I remember correctly
Old 09-03-2011, 01:26 PM
DEMIGOD's Avatar
Pull bezel forward and unplug harnesses
Getting there................
Pull off air dam rubber cover do-hicky
Locate two mounting brackets held on by PITA clips (I used snap ring pliers to remove....still a bit of a chore....)
Got first one out......
Second one is a tight squeeze to get at, but you will get it....trusty flat head screw driver helps as well...
Old 09-03-2011, 01:40 PM
DEMIGOD's Avatar
The 3rd clip, mounting point I didn't even bother with because the space was too tight....I elected to just remove / back out the threaded aiming post from up top, until the headlight was free...used a 5/32 socket and went to town
Well...should be free now.....
Eh, a little tug and she was out............
Now time to start installing...........
Well packaged and good quality...oh forgot to mention I got them in like three days
Sweet.....nice and "chiney"
Side view of mounting hardware...of forgot to mention...they added bulbs too
Old 09-03-2011, 01:51 PM
DEMIGOD's Avatar
Set her in the place and push in to lock tabs up top....re-install PITA clips and adjust to your liking.
Reinstall bezel with turns / side markers. Dont forget to plug them in and replace the nuts / screws that you took off earlier.
Ah....much better now..... 1/2 way home
Remember to put the coolant / washer fluid resevoir back with that single nut and harness connection.
Pass side is same for the most part.....you could remove the battery for a tad more room, but I was being lazy and just slapped them together because it was going to rain....
Finished and looking good
All in all for 40.00 and the price of some snap ring pliers I am really happy. Truck really needed these. Looks like I will be doing the side markers sometime in the future, but not worried about them right now. A+ to the eBay seller, so if you guys are in the market for some, I would order from this guy......cant believe some of the auctions were charging 45.00 to ship...
Hope this helps some peeps out there....oh and please excuse my spelling
Old 09-03-2011, 02:58 PM
86F150302's Avatar
86F150302 86F150302 is offline
86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.
Very nice. Rep points to you
I was hoping you would do some clear lights or smoked. I love how they look on black trucks.
Old 09-03-2011, 04:28 PM
octaneforce's Avatar
octaneforce octaneforce is offline
octaneforce is starting off with a positive reputation.
great post. i literally just ordered new headlights before i saw this. rockauto had them for like 16 bucks a side. did your truck used to be red?
Old 09-03-2011, 06:09 PM
DEMIGOD's Avatar
Hey thanks for the props guys. I plan on getting clear turns and corners soon...I knew I should have bbought them at one time, but funds are tight. I am taking this gem in the rough to TN here in a few weeks to use as a 2nd vehicle when Im up there....I am selling my 89 Jeep Grand Wagoneer if anyone is interested
Yeah, the old gal used to be red.....PO did a real crappy job painting it (bad tape offs, door jams were free handed and tons of orange peel). To bad I am not a Saints or Purdue fan
Old 09-03-2011, 06:16 PM
xc4jokestomper xc4jokestomper is offline
xc4jokestomper is starting off with a positive reputation.
you couldnt of did this like 3 weeks ago could you!?!?
nah im just kidding man. i replaced mine about 3 weeks ago and i still need to reaim mine but i dont want to fool with the clips too much.. very nice write up. rep points to you as well.
Old 09-03-2011, 06:58 PM
Jaime74656's Avatar
Jaime74656 Jaime74656 is offline
Jim
Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.Jaime74656 has a great reputation on FTE.
well im about to do my turns my self, but i thought the bolts that your pointing out were 10MM not 11? unless mine are just some odd size that I have...
Old 09-03-2011, 09:20 PM
DEMIGOD's Avatar
Went and double checked.....mine are 11MM each
Old 09-03-2011, 09:23 PM
Jaime74656's Avatar
Jim
wierd, wonder if mine are 10 or 11...now im tempted to check again too!
Old 09-04-2011, 01:43 AM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
Garrett- No need to undo the whole headlight again...
The 2 adjustment rods that poke out the top of the headlight bezel (Looks like allen wrenches....lol) are what you use....1 dictates up/down....the other dictates left/right....I can't remember right off which one does which though...
Anyways...a simple thing once you figure out which rod does what....
Old 09-05-2011, 09:32 AM
DEMIGOD's Avatar
Correct...you can aim them pretty easy out in the drive way with garage door down......no need to take it out...Mine were pretty close to being perfectly aimed...just needed to adjust vertical positioning
This is a great kit to buy from the eBay seller mentioned in post one....suprised they thre win bulbs
1963 "Wrong bed" Build Thread davewave649 1961 - 1966 F-100 & Larger F-Series Trucks 22 01-18-2015 12:25 PM
New replacement rear window latch install? DEMIGOD 1987 - 1996 F150 & Larger F-Series Trucks 2 09-15-2013 11:30 AM
Finally got to join the club rlt7272 Excursion - King of SUVs 18 07-06-2012 01:32 PM
Door lock replacements (keyed cylinders) DEMIGOD 1987 - 1996 F150 & Larger F-Series Trucks 8 09-16-2011 11:53 PM
New Rims and Tires on the Ex EX_05_v10_Limited Excursion - King of SUVs 18 09-12-2009 09:00 AM
Tags
150, 1993, 1995, 350, 93, change, f150, f250, ford, headlamp, headlight, headlights, removal, remove, replace, truck, xl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
