Roaring noise + vibration - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 09-03-2011, 02:09 AM
jd1987 jd1987 is offline
jd1987 is starting off with a positive reputation.
One other problem my truck has is when I am driving down the road it starts to get a really bad roaring/droning noise between 45-50 mph. I can feel a vibration on the floorboard when in starts. it gets loud enough you almost cant here the person talking in the passenger seat. All my U-joints felt ok to me but i will recheck them. The carrier bearing feels like it might have a little play in it and will have to recheck that too. I retorqued the bolts on the driveshaft coming out of the transfer case and put thm in with locktight blue. Any help would be awesome.
The truck is a 1999 F350 CC DRW 4x4. Only mods are an aftermarket muffler and a superchips tuner. truck has 286k.
Old 09-03-2011, 02:20 AM
strokin one strokin one is offline
strokin one is starting off with a positive reputation.
no vibration in the steering wheel? check rear wheel bearings and things of that nature!!! also if you have the space securly block the rear tires off the ground and have some one opperate your accelerator pedal in gear running and see if your drive shaft has excess play in motion!! i myself believe you have a pinion bearing going out!!
Old 09-03-2011, 02:34 AM
I had to replace my rear leaf springs and when I had my rear tires off everything felt/ sounded/ and looked ok. I will have to check the pinion bearing. Thanks
Old 09-03-2011, 11:58 AM
rbsample's Avatar
rbsample rbsample is offline
rbsample is starting off with a positive reputation.
When you checked the driveline U-joints, did you remove the driveshaft? I had a U-joint that was completely froze up but I didn't know it was bad until I removed the driveshaft. It showed no signs of damage while on the truck but as soon as I removed the driveshaft it was very obvious...I couldn't move it by hand!!
It made a similar noise that you are describing. Good luck!
Old 09-03-2011, 12:34 PM
No I have not pulled the driveshaft out. I just checked them while in the truck and rear wheels off the ground so I could turn the driveshaft.
Need fixed asap! Roaring/vibration in front end Codyg1388 1999 to 2016 Super Duty 23 03-19-2015 07:42 AM
Light roaring noise/vibration when feathering pedal between decel and acceleration queen of spades 1999 to 2016 Super Duty 5 03-11-2015 10:36 AM
Transmission mount vibration? big orange beast Excursion - King of SUVs 5 08-31-2012 04:59 PM
1999 f350 front end problems dakido 1999 to 2016 Super Duty 1 09-25-2006 09:46 AM
Loud roar up front on explorer GucciSock Explorer, Sport Trac, Mountaineer & Aviator 8 07-07-2004 08:48 PM
Tags
1966, 99, back, coming, droning, f250, f350, ford, make, mustang, noise, nova, roar, roaring, truck, vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
