GAS Smell No apparent leaks - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-02-2011, 08:53 PM
Pasadena F-250 Pasadena F-250 is offline
Pasadena F-250 is starting off with a positive reputation.
I hardly ever drive my truck. 03 F-250 5.4L W/ 60,000 miles. The last few times i have driven it maybe thirty miles each way back and forth to home depot while building my deck over the past month, it seems to be sucking down gas faster then usual(maybe this is in my head because of the gas odor???). While driving if i come to a stop with the window down i can smell a strong gas odor, this is when i first noticed it. Then After i park the truck and get out i notice a relatively strong gas odor. its hard to pinpoint but i crawled under the truck and noticed a strong odor around the gas tank but dont see any leaks. i also notice the smell under the hood near the firewall on the drivers side. Other then the smell and possibly worse than usual gas mileage( need to test this thought though) the truck seems fine and runs great. no MIL light or any other cause for concern. Any thoughts or personal encounters with this issue will be greatly appreciated.
Old 09-02-2011, 09:00 PM
Surge08's Avatar
Surge08 Surge08 is offline
Surge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to behold
I would recommend to find someone with a smoke machine or take it to a shop with a smoke machine.
Old 09-02-2011, 09:43 PM
adbanshee adbanshee is offline
adbanshee is starting off with a positive reputation.
oops, double post
Last edited by adbanshee; 09-02-2011 at 09:46 PM. Reason: double posted by mistake
It's funny my 03 had a similar problem when I first bought it. I could smell gas fumes toward the front of the truck. Raised the hood, couldn't see anything amiss, closed the hood, ignored it. After a couple of days it started to really concern me so I looked again Raised the hood, looked for the charcoal canister, located it on the driver side inner fender. Then I noticed the main line that carries vapors from the gas tank was unplugged, plugged it in, no more gas smell, done deal.
If I were you, I would start at the canister and work towards the tank.
Old 09-03-2011, 09:48 AM
bdivine32's Avatar
bdivine32 bdivine32 is offline
bdivine32 is starting off with a positive reputation.
Well you could trace the canister lines, But if you have that many miles, and it sits a lot of the time and your getting poor gad milage, I would be willing to bet you have a leaking injector or two. or if any part of your fuel lines are rubber, they are either cracked or hard so that they only leak when it has the pressure of the pump behind it. and then evaperates. A canister vapor line isn't gonna play with MPG.
When vehicles sit for long periods of time without being ran, seals, o-rings, and rubber lines start to harden and leak... thats why they say that if your vehicle sits for more than a week, just go start it and let it run for a few mins. Just so things get lubed and stay plyable.
Just a thought, but it is still a very good practice!
Old 09-03-2011, 12:32 PM
joeycyph56's Avatar
joeycyph56 joeycyph56 is offline
joeycyph56 is starting off with a positive reputation.
check your fuel filter. i had a similar problem and when i finally looked close the filter on mine had rotted out and would leak under acceleration. no puddles while it sat and it would leak on the inside of the frame rail and wasnt noticable from the outside. it even passed state inspection form a dealer like this. scary.also the filter wasnt even 6 months old ,purolater POS
Old 09-04-2011, 01:00 AM
Thanks Guys lots of helpful info i will Def take a look at these things
Old 09-04-2011, 07:09 PM
Thanks. Fuel filter was the problem. took a good look and noticed a stain on the frame rail. as you stated Joeycyph56 it would only leak under a load my wife hopped in the truck and gave it some gas and then you could see a steady drip until she let off.
Old 09-04-2011, 07:18 PM
As i stated before it would not leak at idle only under a load (a steady drip). i looked in the manual and its says system Fuel press is between 30-55PSI. does anyone know if this is variable press, dependent on load, or should the fuel Press stay a constant press? to me it seems its variable due to the nature of the leak but i always thought that fuel press was a constant. Just curious on the topic, trying to stay educated.
Old 09-04-2011, 08:55 PM
edjunior's Avatar
edjunior edjunior is offline
edjunior is gaining momentum as a positive member of FTE.edjunior is gaining momentum as a positive member of FTE.
I went through this also. My evap cannister line was dried and cracked. I replaced it and it eventually went away.
gas problems forango 1973 - 1979 F-100 & Larger F-Series Trucks 3 03-22-2016 09:50 AM
gas smell coming from a/c Janatur 2009 - 2014 F150 2 09-19-2014 04:22 AM
What's that odor? OldMasterTech 2009 - 2014 F150 8 08-12-2013 07:47 AM
Need Help Smell gas but can not see any obvious leaks Pasadena F-250 Fuel Injection, Carburetion & Fuel System 3 09-10-2011 05:20 PM
strong fuel odor drivembig 1994.5 - 1997 7.3L Power Stroke Diesel 7 10-02-2009 03:28 PM
Tags
58, bad, cabin, driving, e350, f350, fom, ford, fuel, gas, milage, smell, strong, truck, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
