You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I wanted to call this thread "building a truck out of junk nobody wants" but I thought I better keep it simple/ easy to understand.
I have always liked the old ford trucks, I wanted a 4x4 to work on and take on some of the moutain trails around here. I have built and swaped engines in the past, and i have some fabrication experience. I really wanted to do a frame off build up. Overhual everything, paint it, build it strong.
What I have is a 77 f250 4x4 crewcab chassis and drivetrain, the PO wanted the cab for his 2wd cc restoration project. I got a cab and clip from a 78 standard cab to put on it. For now I plan on building some sort of flat bed. the second pick is backwards truck! http://i1093.photobucket.com/albums/...9/IMG_0950.jpg http://i1093.photobucket.com/albums/...9/IMG_0959.jpg
After pulling the bodys off both trucks, and hualing it home, I started this project by pulling the 351m/np435/np205 drive train and tore down the engine. The 351 m had 3 spun berrings and two burnt/cracked exhaust valves, i scraped the engine. I was planing a swap anyway, I'm thinking 460.
With the drive train out of the way, I started striping and painting the frame. I used a 6" cup brush on a big grinder and primed and painted the front half of the frame.
I drilled out the cab/frame mount bracket rivets and repace them with grade 8 bolts with lock washers and lock tite. also replaced the transmission crossmember hardware.
When I started doing the body work I quickly learned why the PO gave me this cab for free. Rust!!!!!!!!! Never fear, let the chopping and welding begin. The neighbors wont like this, thats ok I dont much like their fancy imported luxury cars.
I whent a head and welded in new floors from NPD, I had to fabricate the section that goes under the seat.
I know that feeling. Thankfully, I now live in a neighborhood where they don't mind me and my junk.
Keep up the good work. There is nothing more satisfying than totally building a truck to exactly the way YOU want. I did this same thing to the truck in the picture by my username, and it was great! Now I am hooked on redoing these old trucks.
__________________
Old truck: 74 F250 Converted 4WD sold
Some other 4 wheeled vehicles also reside in the driveway
