F-150 brakes sticking truck shaking - Ford Truck Enthusiasts Forums
Old 09-02-2011, 03:49 PM
Bdlm06 Bdlm06 is offline
Bdlm06 is starting off with a positive reputation.
I have a 2001 f-150 the brakes are sticking and I get a bad shake which seems to come from the front and rear of the vechile. It doesn't do it all the time but when it does it slowly gets worse. I have replaced 3 of the 4 calipers and will be replacing the forth, but not much is changing. Any advice/comment would be great.
Old 09-02-2011, 05:46 PM
trober_603 trober_603 is offline
trober_603 is starting off with a positive reputation.
well i have a 1999 and it done this it would shack on godly and pull so i had the rotors turned all of them and it still done it so i put new brakes on it all the way around still done it and i even put 2 new spindles and calipers on it and still did it.. well come to find out when i took the wheel bearings off i noticed on the left front wheel bearing that it had a defect on one of the races in the bearing and when id turn to the left it would howl and shake so i put new Tempkins ( the best) and it solved all the problems..... hope this helps if u have any ?'s let me know.
Tyler
Old 09-02-2011, 05:47 PM
now for the sticking brakes check the slides that the brakes sit on they could be a bur on them i had a problem on a jeep i worked on they would get stuck and get really really hot and so i sanded the slides down and it worked ever since
Old 09-05-2011, 05:18 AM
Tangosoldier Tangosoldier is offline
Tangosoldier is starting off with a positive reputation.
Sounds like two problems with your brakes.
The vibration in the brakes can possibly be contributed to warped rotors. Have you checked those? Also, it is the job of the master cylinder to provide proportionate braking pressure to the brakes as needed (ie: the pressure you apply, and the fact that the front brakes receive much more pressure than the rear). So the valves in the master cylinder may be going bad. You should look into that before they dont work at all! Its pretty scary when you loose all braking pressure. I dont really see a need to replace the calipers. Are they leaking? Do the pistons look crooked? I assume that with the calipers you replaced the pads as well. Brakes have made a fool of me many times before. I hope you have better luck.
Old 09-05-2011, 07:54 AM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a very good reputation on FTE.Bluegrass 7 has a very good reputation on FTE.Bluegrass 7 has a very good reputation on FTE.
Here is an experience I just had.
Brake pulsing. The faster the speed the worse the brake-down shake.
I knew the right rear pads were worn at an angle so did the service there first.
I was blaming the caliper for being stuck as either the piston or the slides.
The piston was free and the slides were free but noticed one slide was a bit lazy sliding by hand.
Inspected under the rubber boots and found it clean as new no rust or any other situation.
Lubed under the boot just on that slide.
Put the new linings in and reassembled.
Went out for the evening and so far not feeling any brake shake and seems to have a bit better braking.
Need to put more time on the new pads before seeing if the shake was due to the condition found then install new pads on the other side to match.
Seems to show just how sensitive the system can be at times.
Old 09-05-2011, 08:34 AM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
BD, you know this is a brake problem ? It does it while the pedal is applied, or when letting up ? Not when coasting down the road ?
Old 09-06-2011, 07:01 AM
Awesome! good to know. Hope the problem stays gone
Old 09-08-2011, 10:23 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader SwOkcOffRoader is offline
SwOkcOffRoader has a good reputation on FTE.SwOkcOffRoader has a good reputation on FTE.
I've seen alot of later model fords with collapsed brake hoses. Usually fairly cheap to replace. When you think they are sticking, feel the hubs to see if one is hot. If so there is the place to look.
Old 09-10-2011, 08:44 PM
96f150's Avatar
96f150 96f150 is offline
96f150 is starting off with a positive reputation.
....an often overlooked issue that will cause this condition also, would be the parking brake hanging up inside the rear rotors. Do yourself a favor and remove the adjusters and parking brake shoes and then drive it around and see how that does for it. Lots of guys on here have removed there parking brake shoes for good!
Rich
Old 12-04-2015, 06:56 PM
Aaronlasher's Avatar
Aaronlasher Aaronlasher is offline
Aaronlasher is starting off with a positive reputation.
I have a 1995 Ford F-150. Similar problem. My brakes would stick and get hot and eventually lock up to the point I couldn't move. I replaced calipers,pads, flushed fluid, bled the brakes, etc. The most important thing you can possibly do beside making sure the slides and such are greased but replace the rubber caliber lines that lead to the metal brake line. Best thing to replace and solved my whole brake issue. As far as Shake goes. Might be warped rotors. Good luck.
1988 2wd F-150 Violent Brake Shaking nwjones18 1987 - 1996 F150 & Larger F-Series Trucks 14 09-20-2016 08:57 AM
2003 F150 Parking Brake Sticking rjwag 1997 - 2003 F150 2 10-20-2015 11:26 AM
Body Shake When Braking bugmanmyson 1987 - 1996 F150 & Larger F-Series Trucks 1 07-28-2015 09:55 PM
Vibration when braking after replacing brakes and rotors. Michael Naquin 2004 - 2008 F150 11 04-09-2014 12:00 PM
Truck shakes when only when I apply the brakes. titaandbebe 2004 - 2008 F150 4 02-17-2012 05:39 PM
Tags
150, brake, brakes, braking, end, f150, ford, front, jumping, rear, sale, saleen, shaky, stick, sticking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
