putting 6.0 trans cooler in place of 7.3 trans cooler? - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-03-2011, 02:10 PM
MK160 MK160 is offline
MK160 is starting off with a positive reputation.
You certainly don't need to take the bumper off. It took me about 2 hours to swap mine.
MK160
Old 09-03-2011, 02:11 PM
mountie's Avatar
mountie mountie is offline
mountie is starting off with a positive reputation.
A lot easier with it off though.
Old 09-03-2011, 02:33 PM
wildstang's Avatar
wildstang wildstang is online now
VT Chapter Ldr
wildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputation
Being in Vermont and road salt the bumper may have to stay on. Have to see how or if they will Coletta out.
Old 09-03-2011, 05:48 PM
spinella's Avatar
spinella spinella is offline
spinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to behold
also did mine with the bumper on....it was no big deal.
Old 08-16-2014, 03:54 PM
exbxtoy exbxtoy is offline
exbxtoy is gaining momentum as a positive member of FTE.exbxtoy is gaining momentum as a positive member of FTE.
Any updates links with pictures? When pulling my 33ft travel trailer my temps keeps around 212*. I would like them to stay well below 200*.
Quote:
Originally Posted by BigAlsPSD View Post
Here's a great write-up that might help. Courtesy of Ken(WoodNThings)
Ken's 6.0 Transmission Cooler Swap
Old 08-16-2014, 11:52 PM
clem1226's Avatar
clem1226 clem1226 is offline
clem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to behold
Updates are:
It is worth it.
Old 08-17-2014, 01:41 PM
carl2591's Avatar
carl2591 carl2591 is offline
carl2591 is gaining momentum as a positive member of FTE.
link posted on post 14 by ken show a link invalid at google.
anyone know of a good link for the 6.0 tans cooler swap out?
also about how much fluid is needed to replace and for increase cooler size..
Old 08-17-2014, 03:13 PM
KJNDIVER's Avatar
KJNDIVER KJNDIVER is offline
KJNDIVER has a very good reputation on FTE.KJNDIVER has a very good reputation on FTE.KJNDIVER has a very good reputation on FTE.
Try this...
Old 08-17-2014, 03:32 PM
Thanks for posting! Is $600 what I should plan on for doing the upgrade? Any other complete kits and links available other than Beans Diesel?
Quote:
Originally Posted by KJNDIVER View Post
Try this...
Old 08-17-2014, 10:50 PM
carl2591's Avatar
thanks for the link.. it worked great..
I got a used 6.0 cooler off ebay for 100 plus 20 buck shipping.. i believe its the larger size 31 row.
with the good info in the link i feel confident in doing the change out. Guess i may do a complete fluid change out at the same time. I need to get that post by mark on how to use the pump to do a change out.
have a good one
Old 08-17-2014, 11:18 PM
KJNDIVER's Avatar
Old 11-17-2014, 01:18 PM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
Is it worth getting the 6.0 cooler? I found one on ebay for $200 and another one in a local yard for $175. That seems pretty expensive. It seems like the yards have figured out that 7.3 guys like this cooler and raised the price on it.
Can I just get an aftermarket cooler and use it instead? How much more of a PITA is it going to be to mount, install and plumb in an aftermarket cooler? And can anyone recommend a suitable one?
  #28
Old 11-17-2014, 05:39 PM
carl2591's Avatar
i found one on ebay for $135 delivered it was off a wreck? unit., You can find to aftermarket one for about the same. putting it on will be the same difference
PITB pain in the butt.. the OEM one have mounting brackets that match.. maybe the AM ones do was well.
the biggest difference is the location of ouitlet pipes.. on the 7.3 it comes off the top but it is not as tall.. the 6.0 one the come off the bottom. there is a kit with tubing and elbows to help..
check brians transmission website it think.
  #29
Old 11-17-2014, 09:42 PM
Poncho450's Avatar
Poncho450 Poncho450 is offline
Poncho450 is gaining momentum as a positive member of FTE.
I put a TruCool Max from dieselsite.com on my 1997 F Super Duty. 40-50 degree drop. Reasonably priced and fairly easy install.
  #30
Old 03-05-2015, 08:52 PM
Diamnd1's Avatar
Diamnd1 Diamnd1 is offline
Diamnd1 is gaining momentum as a positive member of FTE.Diamnd1 is gaining momentum as a positive member of FTE.
Just bought a 33 row Dorman from Parts Geek for $154.
6.0 trans cooler for 7.3 question... BrokeLoser 1999 - 2003 7.3L Power Stroke Diesel 15 10-30-2016 11:55 PM
Ford 6.0 Trans Cooler Upgrade bigred66 6.0L Power Stroke Diesel 16 08-01-2014 02:56 AM
6.0 coolers fitting a 7.3 7.3 stroked out 1999 - 2003 7.3L Power Stroke Diesel 4 12-13-2013 11:32 AM
No stock trans cooler? Charlie01 1994.5 - 1997 7.3L Power Stroke Diesel 28 07-17-2012 12:58 PM
BTS Trans and 6.0 trans cooler joeyd61 1999 - 2003 7.3L Power Stroke Diesel 23 03-21-2011 08:13 PM
Tags
01, 2002, 60, 6o, 73, cooler, duty, f250, ford, putting, restricted, super, superduty, tanny, trans, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
