Thanks, BuckHammer and the rest who helped me
Just want to thank you all for the great info, and especially for responding so fast. I posted a Help! message 'cause my truck broke and I had to get out of Hurricane Irene's way. Yeah guys, was the vacuum pump. With your diagnosis and step by step instructions, I had it done in no time. I'd have posted a thanks sooner but I just got power back this morning. Again, Thanks BuckHammer,Stainless Stroker95 ,Fordpride. Talyn, DIY Mechanic, Action 4478 and Madpogue. Regards, Vinny
Yeah, we got out in time, Thanks. We{long Island) were lucky. Irene sort of spared us the big blow that was expected. As far as vacuum pumps go. Its a bit scary to me that my 8800 lb truck depends on this thing to stop. Is there anything that can be installed as a fail safe?.......besides a big anchor.
This has been a great thread and could be an example as to what FTE is all about Great Job Guys!!!!
Here is the link to the Original Post & Cry for Help:
https://www.ford-trucks.com/forums/1...renes-way.html
Now I would like to Know more about:
Hydroboost Convertion. ????????
It seems like it could be a great safety advantage.
I've read that drums dont like it very well.
there are goods with the bads.
For actual brake pressure to apply to the rotors, hydroboost rocks.
You basically have to go rob a SD of the brake parts in the engine bay and swap them into your truck.
Master cylinder, some stuff from the power steering pump, yada yada.
I was going to do it at one time, then changed my mind.
Though, if the V-pump goes bad on our trucks, you have no brakes, but you can at least steer.
Metal twister
Fifth Wheel & Gooseneck RV Towing
11-29-2017 08:15 PM
Buck Dharma Fan
13
04-10-2015 07:17 AM
jnewkirk77
04-01-2008 07:25 PM
