Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 09-01-2011, 09:40 AM
woot824 woot824 is offline
Garage is empty, add now
woot824 is starting off with a positive reputation.
shuts off while driving
having problem with engine shutting off while driving will restart with easy moter does not skip or make any kind of noise
  #2 (permalink)
Old 09-01-2011, 01:02 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Check for fuse/relay seating issue on both fuse panels (under dash and in engine bay).
Then the plug on the crank sensor.
If it starts again after a stall, it may be a temperature or vibration sensitive issue.
Good luck.
  #3 (permalink)
Old 09-03-2011, 10:34 PM
briana compton briana compton is offline
briana compton is starting off with a positive reputation.
look on the passenger side of the motor , i had a wiring harness that would touch the exhaust maniford at times and kill the motor.... the harness fell out of it holder .... it started blowing the maxi iginion fuse... hope this helps
Tags
1973, 1994, 2001, 2003, 2010, 49, driving, engine, f150, ford, quits, shuts, shutting, starts, taurus, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
