300 to 302 swap 83 f-100
ok guys i know this is asked alot but i cant seem to find what i need to know. here is what i have i have an 83 f-100 2wd with a 4speed manual trans. i also have a running 1983 mustang gt 302 h.o. what parts am i going to need to put the 302 into the pickup.i known i need the radiator and the flywheel from the mustang. i know i need to get new motor mounts. i guess what i need to know is will the clutch from the 300 bolt to the 5.0 flywheel and can i use the 4 speed thats in the truck or will i need the 5 speed from the mustang. will i need the starter from the mustang or a hole new starter or will the one from the 300 work. as i said i know i have most of the parts needed just need to know what im missing. also please dont say keep the 300 the motor is shot its got a cracked head and the lower end needs a rebuild and the mustang is so rotted it cant be saved i am working on very little money to do this so im trying to take 2 vehicles that are dead and make one out of them.
get the perches from they JY, 302/351 perches were all the same from '80 - '96. I dunno about cutting them off, mine had 3 bolts in them (1982 F100).
what ignition system was on the '83 mustang? if it was DSII then your 300 ignition module should work. so will the distributor.
you'll need a 302 truck engine wiring harness (also JY)
Not sure on the clutch/pressure plate setup
I have done the 4.9 to 5.8 swap. Also did the 3.8 to 5.0 to 5.8 swap in my Capri. Nice thing about them all is they are easy to do and will give you MANY years of service without trouble if you do it right. Good luck
You are going to need a oil pan for the 302. The one from the mustang I have heard will work, but you can't get to the front drain plug after you install it in the truck. The mustang pan is dual sump while the truck pan is rear sump. Have you thought about what you are going to do about a fuel pump, carb and intake manifold for the 302? You are also going to need the truck exhaust manifolds and the y-pipe for the exhaust.
im going to run straight pipes into glass packs off the stock manifolds on the mustang. ill have to measure to see what type of clearance i have but thats the least of my concerns. im not sure about the oil pan clearance ill have to check into that with mine being a 2wd i dont think im going to have the same issues as people with 4wd if so no big deal. fuel pump carb and intake im just going to leave the way it is same with the power steering pump the 302 is all intact in the mustang and runs the way it is.
Interesting, My 88 F250, 85 F150 (donor truck) and the 80 F100 have all had the drivers rivited. Not sure about the 86 that is Canada built.
Sorry, I saw 5.0 and I had fuel injected engine in my mind. 2wd and 4wd both take the same rear sump oil pans though. I believe if it wasn't mentioned already, the truck six radiator is different than the v8 truck radiator. And of course you can probably rig anything to work, but it will be up to you how much custom fitting you are going to want to do. It sure is nice and a real time saver if everything just bolts in, and it will if you get the correct original truck parts.
