87 F350 460 miss
87 F350 460 miss
Hello all,
I got a 87 carb f350 with a miss that occurs all through the driving range. I put my old spark checker on it and on one wire it didn't light up. So I swapped the wires out and getting fire on all wires but still missing????? The back cylinder on the drivers side plug was oily as hell so I put in a good plug and it still misses. I also real quick did a compression check on that cylinder and it was holding at 100psi but I didn't check the others yet and the engine was warm. Also cap and rotor button have been changed also. It also sounds like a exhaust leak on the drivers side of the engine. Kinda poppy sounding ???? I am thinking something valve related maybe? Any help would be appreciated!!!!
I forgot to add when I was messing with it I could unhook that back cylinders plug wire and there was no change in engine running condition but there was when disconnecting anyother plug wire.
1975MudRat
10-18-2012 12:48 AM
btorear
05-16-2008 02:50 PM
caphuff
01-10-2005 10:29 AM
