problem w/sct tuner pleasse help - Ford Truck Enthusiasts Forums
Old 08-31-2011, 10:12 PM
Eagle Custom's Avatar
Eagle Custom Eagle Custom is offline
Eagle Custom is starting off with a positive reputation.
I just bought a 04 F-350 4x4 with 144000 miles it has a 4" exh. and k&n cold air intake and today I bought a new sct sf3 with canned tunes when I installed the street or the tow haul tunes the truck will not run it will start and runs real ruff and then dies when I put the performance tune in it would run but is more than I want on my truck. So now it is back on stock and running again any body else had issues with SCT.
I have emailed SCT to inquire about this issue but wanted to know if any one else has the same issue.
Old 08-31-2011, 10:43 PM
Robs06SuperDuty's Avatar
Robs06SuperDuty Robs06SuperDuty is offline
Robs06SuperDuty is gaining momentum as a positive member of FTE.Robs06SuperDuty is gaining momentum as a positive member of FTE.
It might be worth it to just get some custom tunes from SCT, Im actually getting ready to buy an SCT X3 for my truck with custom tunes to liven my truck up a bit.
Old 08-31-2011, 11:05 PM
I am kicking that idea around now but am not happy at all that a tuner bought today and installed does not work they are pretty pricey for something that does not work like advertised has anyone had simmilar problems.
I am not trying to bash SCT as I have not talked to them as they were closed when found the problem hope fully they will have a simple fix for this or I might have done something wrong as this is my first time using a tuner.
Old 08-31-2011, 11:09 PM
djanzen's Avatar
djanzen djanzen is offline
djanzen is gaining momentum as a positive member of FTE.djanzen is gaining momentum as a positive member of FTE.
go with matt at gearhead!!! his tunes are frikin awesome. I run his with a sct sf3 and my truck has never shifted as smooth!! matt Rocks!!
And his tunes are cheap
I would go through the install again making sure everything is correct.
Old 09-01-2011, 03:38 AM
Tylus's Avatar
Tylus Tylus is offline
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
the canned tunes that the SCT comes with are designed for a bone stock truck. any modifications will cause problems like you are experiencing.
Your K&N is most likely causing the problem. If you have the stock airbox, I'd throw that back on there and try it again. Most likely everything will run fine.
Old 09-01-2011, 09:47 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 6.0L Powerstroke Diesel forum.
Old 09-09-2011, 08:03 AM
demondog05 demondog05 is offline
demondog05 is starting off with a positive reputation.
Same issue I am having on my 2005 6.0L King Ranch with EGR delete. Just bought the truck last month and got the SCT tuner. Except mine does'nt like any of the preloaded tunes. I always have to return it to stock tune to get it run again. I have not checked to see if the previous owner had done any mods or perhaps installed a performance chip. That might be something to check next time I am home. Currently deployed so it will have to wait.
Old 09-09-2011, 11:29 AM
strokethis04's Avatar
strokethis04 strokethis04 is offline
strokethis04 is starting off with a positive reputation.
Give SCT a call. They will surely help you out with your issue, guaranteed!
Old 09-10-2011, 05:23 AM
Tylus's Avatar
Quote:
check it over
My 2009 Mustang refused to run when I used the canned tunes on the SCT #3015 tuner. Those tunes were setup for the K&N or C&L CAI. I had the FRPP CAI. A very tiny seeming difference, but it was enough that the car couldn't even idle.
With the canned tunes, they are written for an assumed stock vehicle. So if you have any extra mods, you must buy Custom tunes.
Old 09-10-2011, 06:06 AM
I have been in contact with Matt from Gearhead automotive and he is getting me squared away. I will post later what develops.
Old 09-10-2011, 06:28 PM
Awesome hes a great guy to deal with!
Old 07-29-2012, 12:34 AM
hdmall hdmall is offline
hdmall is starting off with a positive reputation.
I have an sct tuner , have used it on 2- separate, 04 fords, worked perfect, used on my 06 , now truck wont start, and wont go back to stock,,,,help----waffordranch5@hotmail.com
Old 07-29-2012, 01:03 AM
Ian123's Avatar
Ian123 Ian123 is offline
Ian123 has a very good reputation on FTE.Ian123 has a very good reputation on FTE.Ian123 has a very good reputation on FTE.
Quote:
Originally Posted by Tylus View Post
check it over
Can anyone else confirm this? I hope you don't take offense to me doubting you but I've just never heard this before. I've used canned tunes on previous vehicles that had aftermarket intake and exhaust with no issues
Old 07-29-2012, 05:25 AM
Tylus's Avatar
Quote:
I bet you used the tunes for the 04 truck on your 06 didn't you?
The 03/04 trucks had/have different PCM strategies from the 05/06/07 trucks.
They are not interchangeable. You aren't completely screwed though. Contact SCT and tell them what you did. They have a work around that they'll walk you through. Hopefully that'll get you back on the road.
For future reference, make sure the tunes you are running are for the same PCM strategy as the truck.
Quote:
no offense. I've learned the hard way with SCT. It started with the blower on my F-150 and many trial & errors with my Mustang and this truck. I've had 5 different SCT tuners. The X2, 2 of the X3's and 2 of the SF3. The X2 is my favorite though.
how extensive was the exhaust?
just a catback - motor/PCM won't know the difference.
longtube headers - O2 signals are timed. the pulses will not be correctly synched with the new location in LT's. not to mention the higher exhaust velocity. I had to get 3 re-tunes, and 2 different tuners to get my Mustang to run properly when I did the LT's with offroad H. PCM kept defaulting to pig rich conditions because of O2 sensor issues...and Brenspeed being retards who won't listen to the customer vehicles specs and desires. Blow By Racing got it right the 1st time and actually listened to my requests. Great guys. Not to mention their tunes made 1st and 2nd gear useless for traction
most people think the "mods" they've done really change things up. truth be told, most "mods" people do are bandaides and really don't do diddly. A simple K&N intake won't really be noticed by the PCM. Same with the catback. It'll look and sound better, but not really perform. Kinda like putting a sticker on the window and expecting +10 hp
now, if you install a true replacement intake that relocates, or significantly changes things up...then you need tuning.
as I mentioned in my previous post, I had the FRPP CAI on my Mustang Bullitt. I tried using the SCT SF3 (p/n 3015) canned tunes. Since the FRPP CAI is a true CAI vs. the K&N wanabe, the parameters of the SCT tuning couldn't make the PCM and CAI play nice. The car tried, but after a few seconds of stumbling and barely idleing, she'd die out.
think about it this way. SCT has the enviable job of writing "canned" tunes for every single variable that the motor might experience. To be safe, they really limit how much they tweak. And the assumption is that the vehicle is stock, or near stock with a CAI (only certain CAI's are supported btw). So SCT writes this very generic tune with extremely safe margins to prevent blowing up or otherwise damaging the vehicle. It must fit a multitude of vehicles, so what you are really getting most times is just transmission tuning...and/or a little bit of spark advance to allow for running 89/91 octane fuel
now when you add mods outside the little box that SCT is working with, things won't go right. the PCM has no idea what to do, and the "canned" tunes aren't any help.
Old 07-29-2012, 05:27 AM
Tylus's Avatar
btw, I'm watching Army of Darkness at the moment, so please don't take offense. I always get all riled up by that movie.
g'night to all and Thank you generous hosts
SCT x4 vs. edge evolution rbrungard2012 1999 - 2003 7.3L Power Stroke Diesel 13 11-04-2016 12:14 AM
SCT X4 tire revs issues with custom tunes jlmotox 6.0L Power Stroke Diesel 6 07-17-2014 02:29 PM
SCT wont load custom tune? Failed to write data? bigugly78cj5 Computer Chips & Tuners 2 11-07-2012 07:25 AM
Saving Custom tunes (sct) BIRDMANN79 Computer Chips & Tuners 3 04-11-2012 07:02 PM
SCT & Edge Evolution CTS?? anyone using both? southbound35west 6.0L Power Stroke Diesel 2 05-23-2011 02:11 PM
Tags
03, 64, buy, cheapest, display, duty, f250, ford, loading, place, problem, problems, sct, super, tuner, tunes
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
