6.0 Oil Temp - Ford Truck Enthusiasts Forums
6.0 Oil Temp
Old 08-31-2011, 08:51 PM
usmcknight69 usmcknight69 is offline
usmcknight69 is starting off with a positive reputation.
6.0 Oil Temp
Can anybody tell me what the normal operating oil temp is? I read somewhere on this forum that anything over 150 degrees is bad. My operating temp on a 85 degree day doing normal driving is about 185 degrees. I got that reading off my bully dog. Not sure how accurate it is. Before any comments come thundering down about the bully dog, I switched to the SCT Livewire today. Much better choice. Only question about the Livewire is....When I installed and took it for a test drive, at WOT, it seemed to hesitate a little. Not sure what that was. Almost like it wasnt getting enough air.
Old 08-31-2011, 08:59 PM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is offline
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
Old 08-31-2011, 09:04 PM
Quote:
Originally Posted by amdriven2liv View Post
Thanks driven! That is perfect. Guess my oil temp is good considering i am running a tuner.
Old 08-31-2011, 09:08 PM
If your temp on ECT is that low, Your "T" stat may not be working properly, might think about changing it. Your ECT should be at 190 and up. The stock T-stat is designed to fail "open".
And "Bully" for you on changing to SCT!
Old 07-11-2015, 08:07 PM
6.ooh 6.ooh is offline
6.ooh is starting off with a positive reputation.
I have a 06 6.0 wondering if my oil/coolant temps are too high I live in Alberta n today's temp was 28 degrees n when the truck is fully warmed up the terms are in the low 90,s when driving coolant hits 96 oil is +- 4 is this average I am getting these readings from my sct, anything on it would be great thanks.
Old 07-11-2015, 09:32 PM
evan1242's Avatar
evan1242 evan1242 is offline
evan1242 has a very good reputation on FTE.evan1242 has a very good reputation on FTE.evan1242 has a very good reputation on FTE.
6.0 Oil Temp
Do you mean 190's or actually 90 something degrees. And are you talking °F or °C
Old 07-11-2015, 10:08 PM
2006White60's Avatar
2006White60 2006White60 is offline
2006White60 is gaining momentum as a positive member of FTE.2006White60 is gaining momentum as a positive member of FTE.
Quote:
If you are talking Celsius that would be 194* to 204* with oil temp being with in 4* and if the 28* which would be about 82*, that all sounds good to me.
Old 07-12-2015, 03:24 AM
Yea I mean Celsius, n thanks 2006white60
Temp Gauge Spikes and Falls JamesMcMn 1999 to 2016 Super Duty 5 11-05-2016 04:56 PM
Programmer vahunter23 2009 - 2014 F150 5 02-15-2016 08:39 PM
Programers for 2012 6.2L F250 SGTYuengling Computer Chips & Tuners 14 08-24-2014 03:29 PM
Just replaced oil cooler again, still high delta vatreefarmer 6.0L Power Stroke Diesel 71 08-09-2014 08:48 AM
My Bully Dog readings on my Gauges are they messed up. Canadianpowerstroke 6.0L Power Stroke Diesel 8 07-18-2012 10:57 AM
Tags
2004, 2007, 60, code, diesel, engine, f250, ford, high, normal, oil, temp, temperature, temps, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
