Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 08-31-2011, 07:35 PM
thinksnow thinksnow is offline
Garage is empty, add now
thinksnow is starting off with a positive reputation.
NASA I thinik we have a problem
This is baffling me. I changed the wife's oil tonight. Everything went fine, nornal oil change. When cleaning up I noticed the rubber ring on the old oil filter was missing. Looking back the filter was tighter then usual getting it off. When I took the old filter off I wiped down the surface lilke I always do and didn't notice or feel anything unusual. I have searched high and low for the missing O ring to no avail. The truck is running fine and the oil pressure is fine. I got under the truck whille it was running to check the filter. It appeared to be seated fine and there was no sign of any leakage. The only thing I can think of is the old ring was stuck to the filter mount and the new ring seated against it. Is this possible and is it dangerous???
  #2 (permalink)
Old 08-31-2011, 08:01 PM
brucebowker's Avatar
brucebowker brucebowker is offline
brucebowker is starting off with a positive reputation.
I really don't think a seal against a seal as such is safe. If indeed this is the case, it may last a long time or leak at any unknown moment. The design is for one only. I would certainly check just to ease my mind.
  #3 (permalink)
Old 08-31-2011, 09:24 PM
dgruhlke dgruhlke is offline
2007 Ford Expedition
dgruhlke is starting off with a positive reputation.
The ring is stuck to the filter mount-- I would definitely remove the filter and scrape the old ring off.
  #4 (permalink)
Old 09-01-2011, 10:37 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Just buy another filter and put it on. $5 is worth your piece of mind.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #5 (permalink)
Old 09-01-2011, 11:20 AM
Johnny Law Johnny Law is offline
Johnny Law is starting off with a positive reputation.
I had this happen on my Generator. It will eventually vibrate loose. and you will loose all your oil (at least a very high chance). Thankfully my generator shut down at loss of oil pressure and I didn't damage anything as far as I can tell. But in a car/truck, it's a whole different matter.
I will not put on another oil filter now without checking the old one first.
Change it! Or at least check it.
Johnny
  #6 (permalink)
Old 09-02-2011, 09:11 AM
function12's Avatar
function12 function12 is offline
function12 is starting off with a positive reputation.
I have had that happen before and it started leaking a few days after. Not good. I had to do a mini oil change in a parking lot because a lot of oil came out.
__________________
See ya,
Eric
  #7 (permalink)
Old 09-02-2011, 09:54 AM
neitz neitz is offline
neitz is starting off with a positive reputation.
I had this happen as well on an older mustang and like others said, I lost all my oil within a week. Scared the hell out of me because I started it up one day and it just started shooting oil out underneath in the garage. Shut it down real quick and couldn't figure it out because oil was everywhere. So guessed at it and when I spun the filter off, there was the old and new rings double stacked. I was happy to dump another $40 of oil and filter into it vs what else I thought could have been wrong. So the good thing is that you realized it. One thing is, you will always double check now going forward!
Tags
nasa, official, vehicle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
