2002 mountaineer?
2002 mountaineer?
Hello i am usually on the diesel forum here but my sisters mountaineer (4.6) is throwing a code of misfire for no 6 cylinder.
recently no 3 spark plug blew out of the head and we have fixed that and replaced that coil and all 8 plugs.
now she has that codee. so i just put a new coil on no.6 and light was right back on.
any ideas on what to do next?
also anyone verify i have the right cylinder? here is what i think they are.
firewall
4 8
3 7
2 6
1 5
radiator.
thanks for any help
firewall
4 8
3 7
2 6
1 5
radiator.
thanks for any help
You have the correct cylinder, and your diagram is accurate. You should start by pulling the spark plug and inspecting it. While you have the plug out, you could check the compression on the cylinder to make sure it isn't abnormally low. You could also swap the spark plug with another one, assuming you don't see something obviously wrong with it. You might also swap the coil with yet another cylinder, then see if the code remains on cylinder #6, follows the spark plug, or follows the coil. If it follows one of the parts, I think that's pretty self explanatory. If it remains on the cylinder then you likely either have a compression issue or a fuel injector issue.
-Rod
-Rod
If the cylinder is not getting the proper air fuel ratio, it's not going to fire reliably = misfire. Yes, a fuel injector that is allowing too much fuel or one that is not allowing enough fuel can also cause a misfire, as could a vacuum leak that is allowing in too much unmetered air.
-Rod
-Rod
It could be a fuel issue, and if you're going to shotgun a part, a routine maintenance item such as a fuel filter is not a bad place to start. However, I'd rather see you check the fuel pressure at the fuel rail with a fuel pressure gauge to determine if the pressure is within spec.
You mention you now get three codes but mentioned four. Please confirm the code numbers, are they P0301, P0306, and P0300?
-Rod
-Rod
