drivetrain CLUNK... - Page 2 - Ford Truck Enthusiasts Forums
drivetrain CLUNK...
Old 10-28-2012, 08:04 AM
D8chumley's Avatar
D8chumley D8chumley is offline
Resident smarta$$
D8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud of
Quote:
Originally Posted by califord2011 View Post
Ahh yes this infamous clunk sound!!! So far I've taking my 2011 F150 back to the dealership twice to FIX this clunk sound and bump feel when coming to a complete stop and also when taking off from a complete stop. First time I took my truck in the work order reads as follow; "Verfied clunk found TSB 12-07-13. Removed grease cover and checked splines. Applied grease to splines. Installed new boot and clamps. Road test - Clunk gone."
The second time I took my truck in for the same reason the work order reads as follow; "Verified bump stop. Reprogrammed PCM to latest calibration road test and bump stop gone."
I have a appointment this Wed 10/31/12 for the third time to try and get this dang clunk/bump feel when tanking off and stopping FIXED. I really don't know why this is becoming such a big issue... I guess I should've bought a Silverado instead. Any suggestions???
Go buy a Silverado
Old 10-28-2012, 11:14 AM
califord2011 califord2011 is offline
califord2011 is starting off with a positive reputation.
Lol as soon as I'm allowed to by the finance company I'll be trading it in if its not fixed this time. Sucks I had a lot of faith in Fords.
Old 10-28-2012, 12:25 PM
D8chumley's Avatar
Resident smarta$$
Sorry to hear of your misfortune, all brands have their issues. Hopeully Ford fixes it for you and you continue to bleed Blue
Old 10-28-2012, 01:11 PM
Quote:
We'll see. Thanks bud!
Old 10-28-2012, 02:07 PM
D8chumley's Avatar
Resident smarta$$
No problem, welcome to FTE!
Old 10-28-2012, 06:03 PM
blueovelboy's Avatar
blueovelboy blueovelboy is offline
blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.
you know my brothers truck never Had A PROBLEM (2010 F150 CREW CAB 4X4) me my 2010 crew cab 4x4 clunk every time i drive it! so i offed it and got a 2012 crew cab 4x4 and no more slip bump with 3000 miles on it. knock on wood!
Old 10-28-2012, 08:03 PM
Quote:
Nice! But yeah knock on wood brother.
Old 11-08-2012, 12:19 PM
Update: Took my truck in for the third time and same bump feel its as if nothing was done "technician" said that's as good as its gonna get nothing is wrong its just the characteristic of the truck and that it won't cause me any future problems. Well I think that's a bunch of bull but we'll see only time will tell.
Old 11-08-2012, 04:36 PM
TheStuffz's Avatar
TheStuffz TheStuffz is offline
TheStuffz is gaining momentum as a positive member of FTE.TheStuffz is gaining momentum as a positive member of FTE.
im noticing a little clunk from reversing, neutral, into drive.
what has me worried is that on the rear axle, drivers side, front half springs don't look too straight and there is rub marks near where the brake lines are on the springs yet i dont feel anything on the lines... 850~ miles on the truck to..
Old 11-10-2012, 12:05 PM
luke2233 luke2233 is offline
luke2233 is starting off with a positive reputation.
2009 F150 STX 4.6 v3 with 6 speed tranny. Have same clunk issue. When slowing down and then give it some gas, feels like bottom dropping out of truck. It is much worse when towing say uphill hard and it has to down shift. It's not the first downshift but the second. Took it to the dealer and they reprogrammed it. It is not gone, but happens a lot less.
Old 11-11-2012, 04:53 PM
Aggie-150 Aggie-150 is offline
Aggie-150 is starting off with a positive reputation.
My '10 XLT 4x4 has the clunk too. I have a one piece driveshaft, but everyone else seems to have the two piece? The dealer still did the TSB for greasing the slip yoke and it drove butter smooth for about 600 miles and now the clunk is coming back.
What exactly is the problem? Are the male/female connections too loose causing the play? Can buying a better slip yoke that fits better stop the clunk? I read somewhere on a Ford forum that a guy took a thick rubber hose and basically jammed it between the threads of the male and female components and it stopped his clunk. I plan on keeping this truck to over 200,000 miles and I'm afraid that wont happen unless there's a permenant solution for the clunk. Our 01 Expedition has over 140k on the clock and runs perfect
Old 11-12-2012, 11:27 PM
B's FX4's Avatar
B's FX4 B's FX4 is offline
B's FX4 is starting off with a positive reputation.
is anyone having this issue with the 3 73 gears? on side note Id guess that the standard axle is less likely to have this noise....
  #28
Old 03-12-2013, 09:47 AM
Roger C's Avatar
Roger C Roger C is offline
Roger C is starting off with a positive reputation.
I get a clunk in my 66 when I let off the gas. Motor and trans mounts are tight. previous owner thinks pinion needs to be tightened but that is coming from somene who had a 2700 Variable venturi carb on it and brushpainted white rustoleum everywhere. I have noticed that rear spring bushings are shot. I think that might be the cause. The bolts are welded on the ends so removing the springs are going to need a sawzall . Was it common to weld the bushing bolts to prevent theft? anyway I'm not convinced its the pinion. All help and opinions are appreciated!
  #29
Old 03-12-2013, 02:13 PM
just a update i have over 9000 miles now on my new truck. it still don't do it and its a spitting mirror image of the the 12 with the slip bump!
Last edited by blueovelboy; 03-12-2013 at 11:23 PM. Reason: to drunk to make it worth it
  #30
Old 03-12-2013, 03:56 PM
Roger C's Avatar
just a update i have over 9000 miles now on my new truck. it still don't do it and its a spitting mirror image of the the 07 with the slip bump!
I had zero issues on my 07 F-150 4x4 5.4l in 100k miles inspite of it being union made.
Truck saying "clunk, clunk, clunk" MDSuperDuty 1999 to 2016 Super Duty 2 07-23-2016 09:19 AM
Mountaineer front clunking noise wagne020 Explorer, Sport Trac, Mountaineer & Aviator 6 05-12-2016 10:38 PM
2004 Escape clunk while turning. crazn Escape & Escape Hybrid 0 04-11-2012 08:19 AM
'97 Explorer makes clunking sound going into 4-wheel drive. tbone1376 Explorer, Sport Trac, Mountaineer & Aviator 13 12-04-2010 03:56 PM
Clunking Between Bellhousing and oil pan.. timbersteel 1987 - 1996 F150 & Larger F-Series Trucks 5 10-14-2010 04:08 PM
Tags
2002, 2010, clunk, clunking, drive, driveline, driveshaft, drivetrain, econoline, excursion, explorer, f150, ford, loud, lube, reverse, spline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
