Missouri Chapter Join Chapter , Leader:77&79F250
Compression questions
Old 10-01-2011, 04:17 PM
Hammertime01's Avatar
Hammertime01
Hammertime01 is offline
I have a 1976 Ford F 150 with a 360 Fe,
my compressions are as follows
1: 111 psi
2: 95 psi
3: 111 psi
4: 105 psi
5: 111 psi
6: 105 psi
7: 80 psi
8: 109 psi
Is this ok or do I have problems
what is the compression supposed to be stock
Old 10-01-2011, 04:58 PM
j20owner's Avatar
j20owner
j20owner is offline
IMO all of those are very low. Should be close to 75psi on the first pump and over 125 after 4. Is the engine currently able to run? I'd say warm it up good and then check again. Also, make sure you hold open the throttle blades while cranking over and have a battery charger on it at the same time. That way you won't deplete the battery while doing the check.
You might also squirt a shot of oil into each cylinder immediately before testing to see if it helps the rings seal better.
Old 10-01-2011, 07:14 PM
earthquake68's Avatar
earthquake68
earthquake68 is offline
That engine should have about 130psi(ish in every cylinder. J20 (sorry I forgot your name) is right on how to check them. My thoughts are bad valve seats. If this is the case the oil trick won't matter much. If it's rings, the compression should go up a little.
After all, the engine is 37 years old. I'll be 39 in a couple months and I'm worn out too. It may be time for a rebuild.
Old 10-01-2011, 07:42 PM
Hammertime01
Thanks guys. Earthquake you make a lot of sense and that's hilarious
Old 10-01-2011, 09:08 PM
tcbofade's Avatar
tcbofade
tcbofade is offline
I'm betting valve seats as well...good luck!
Old 10-01-2011, 09:19 PM
Hammertime01
Ill be working on it soon ill let y'all know I appreciate the replys.
Old 10-01-2011, 09:20 PM
Hammertime01
O and yes the engine does run and it even runs strong it just sounds like crap.
Old 10-01-2011, 11:56 PM
Hammertime01
marshallstanford
07-15-2016 06:42 AM
JGuillen99
04-27-2016 04:26 PM
nickydobbs
09-17-2014 11:58 PM
darsacal101
1983 - 2012 Ranger & B-Series
02-29-2008 02:22 AM
bshackelford711
07-27-2005 02:22 PM
Quick Reply: Compression questions
