92 f150 5.0 idle problems - Ford Truck Enthusiasts Forums
Old 08-31-2011, 04:02 PM
captain1997 captain1997 is offline
captain1997 is starting off with a positive reputation.
Hope someone has some advise, I have run out of ideas! I have a 92 f150 4x4 with a 5.0,and it idles really high it revs up quickly but it goes back down really slow and idles way to high. I have checked for vacuum leaks,intake manifold leaks,and removed and cleaned the IAC. I even replaced the IAC with a couple of other ones I have laying around. When engine is warmed up and I unplug the IAC the idle goes down,and once in a while it goes so low it stalls the motor but it starts right up. What could be the problem? I know these 302's very well but this one has me stumped. I want to thank you ahead of time for any help.
Old 08-31-2011, 10:02 PM
tsarge78 tsarge78 is offline
tsarge78 is starting off with a positive reputation.
ya this is a pain I have the exact problem myself my IAC was pretty built up with carbon but after I cleaned it still no change. It almost seems to be higher now. going to start back at square one and check all vacuum lines and canisters and go from there. Ill keep you updated with what I find.
Sarge
Old 09-01-2011, 09:38 AM
Thanks Sarge,
I am going to do the same start from square one and see if I possibly missed something. If I find something out I will share it with you. I really hope my IAC isnt bad. They are quite expensive over 100 buck at auto zone, but I may have to buy a new one just to try it out. Pulled the one off my 89 mustang which I know works(at least it does fine on the HO 5.0) and i get same result. Oh well I will keep looking
92 f-150 5.0 high idle, new iac and tps Anthonynoble 1987 - 1996 F150 & Larger F-Series Trucks 14 08-24-2016 04:13 PM
high idle issue...help please! troubled1 1987 - 1996 F150 & Larger F-Series Trucks 15 08-24-2016 04:12 PM
Very high idling... after cleaning iac Jonathan Stone 1987 - 1996 F150 & Larger F-Series Trucks 4 08-24-2016 04:11 PM
some questions RadioControlGuy85 1987 - 1996 F150 & Larger F-Series Trucks 14 08-01-2015 10:34 PM
5.0 erratic idle and burning rich with a miss Chris Braun 1987 - 1996 F150 & Larger F-Series Trucks 5 05-07-2014 08:54 AM
Tags
1987, 2011, 50, 92, air, control, eng, f150, high, idel, idle, idles, mustang, problem, problems, warm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
