cold start - Ford Truck Enthusiasts Forums
cold start
Old 08-31-2011, 03:29 PM
jpmiller91493 jpmiller91493 is offline
jpmiller91493 is starting off with a positive reputation.
cold start
my uncle is having a problem. 1998 3.0. its like starting a tractor cold without a choke. it cranks for a second, starts, then stalls imediatly. does that 2 or 3 times then stays started. when it does start it idles rough until it runs for a minute. any ideas.
where are the temps sensors at. are there 2 or more temp sensors. i was reading that one tells the computer that the motor is cold and the computer keeps the injectors open longer when cold. where is this sensor?
thanks.
Air Charged Temperature Sensor Mikes '66 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 01-09-2017 08:47 PM
1988 f 150 5.0 cold start patio1953 New Member Introductions 3 04-30-2016 12:50 AM
Temp sensor for glow plugs system cornking Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 02-16-2012 03:55 PM
EATC Sensor Location miker67 Excursion - King of SUVs 3 11-26-2010 09:36 AM
V10 Coolant Temperature Sensor Location? suprdutyv10 1999 to 2016 Super Duty 0 02-20-2010 09:30 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
