You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Does anyone get a chattering noise for the first 2/3 seconds on a cold startup? My old 98 Navi did this and now my 07 does as well. It only happens if the truck sits for at least 3-4 hours OR the first startup after an oil change (does it longer the first time) and and goes away after a few seconds.
It seems to be worse in the cold/winter but not sure what it could be.
I had a tapping that just never went away at 10K miles, ended up replacing one of the heads. THen at 50K or so I got a marble sounding rattle on start up. It ended up being the timing chain tensioner gaskets and tensioner arms worn out. After they replaced that its fine.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
I took it into the dealer last year and they said not to worry as it may make that noise when cold. I didn't bother pushing since it only happened if the truck sat overnight.
now it's happening if the truck sits for even 30 mins and when it's warm aswell.
Here is a vid of the noise. Just want to see if this is the noise you were getting and in case you think it could be something else.
They need to remove valve rocker arm covers, front timing chain cover and the parts are about $250. Not sure what labor will be as mine was under warranty. I would guess your looking at $500+. Get a price before the work is begun. They know what it will cost.
__________________
Awww shoot. Mine just recently developed this noise. It doesn't last as long as yours, but it's definitely there. I am very interested in how your repair goes.
