Dodge dual piston rear disc (e-brake) conversion - Ford Truck Enthusiasts Forums
Old 08-31-2011, 10:39 AM
Goliath1975's Avatar
Goliath1975 Goliath1975 is offline
Goliath1975 is starting off with a positive reputation.
Hey everybody, I was wondering if anyone on here had done the rear disc conversion using a 2002 Dodge 2500 rear disc setup? I like the setup because it has a drum style e-brake inside the rotor and it's dual piston. The parts are more, about $500 for everything unless I can find some cheaper sources than the auto parts stores. I love my local junkyard, but they don't have anything that new. I got the idea from this website:
Ford Rear Disc Brake Kits for 9", Dana 60, Dana 70 and Sterling
The total parts list looks like this:
Rotors $150
Brackets $055
Calipers $200
Pads $030
E-brake shoes $055
E-brake hardware kit $017
Total $507
If anyone has any better parts sources or has done this swap, help me out!
Old 08-31-2011, 11:56 AM
helipirate helipirate is offline
helipirate is starting off with a positive reputation.
I haven't looked at this swap much, but you could do a disc swap using new 79ish Cadillac Eldorado calipers and new Chevy K20 rotors for half the price and still have an ebrake. Don't know if it is dual piston but who cares it is on the rear and a single piston would have no problem locking it up. Do a search there is lots of info and how too's.
Old 08-31-2011, 02:51 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.
Haven't heard of using the dodge stuff before but it sounds interesting. The parking brake is similar to the setup used on the newer Exploders (Explorers)
Old 08-31-2011, 08:51 PM
4x4 Bart 4x4 Bart is offline
4x4 Bart is gaining momentum as a positive member of FTE.
I think this might be a better setup than the eldorado because it is newer and parts would be available. The eldorado calipers are rare and expensive along with strange cable angles and lengths needed and The odd mounting to get the bleeder at the top.
I would like the Dodge, having a separate brake shoe, for the parking brake.
Old 08-31-2011, 09:42 PM
I had looked at the Eldorado setup and while I haven't completely ruled it out, I don't like how the e-brake mechanism is completely exposed to the elements. On top of that, the Caddy stuff isn't a whole lot cheaper. I may not need the dual pistons, but they would be nice and of the e-brake setups I have worked on, I like this style the best.
Old 08-31-2011, 11:09 PM
Also, I believe you can use the Chevy rotors with this setup. The rotors are only 75thousandths difference in thickness.
Edit: The Chevy rotors wouldn't have the "Hat" design necessary for the internal drum e-brake.
Old 09-01-2011, 09:55 AM
POPAJON POPAJON is offline
POPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud of
LMC has a rear disc kit now to. I believe it's expensive about $ 700.00/ e breake. John
Old 09-01-2011, 10:07 AM
John, what style of e-brake does it have? I found this kit on Currie's website, but not sure what brake offset the D60 has? It's a really nice kit and the it'd cost about the same as the dodge setup if it would work...
Old 09-01-2011, 10:32 AM
F-250 restorer's Avatar
F-250 restorer F-250 restorer is offline
F-250 restorer has a good reputation on FTE.F-250 restorer has a good reputation on FTE.F-250 restorer has a good reputation on FTE.
Maybe things have changed, but aren't the dual piston calipers notorious for always having one of the pistons freezing?
@ Goliath, sorry I should have mentioned that that kit from LMC is for 9" only. It is in the 2011 summer catalog, last page. Apparently you use your original E- brake cables and it fits 15" wheels, single piston calipers and it costs WOW!!!! i stated the wrong price $ 800.00. Don't think they'll be selling too many of those at that price. John
Old 09-01-2011, 12:56 PM
PA74F250's Avatar
PA74F250 PA74F250 is offline
PA74F250 is starting off with a positive reputation.
Quote:
I don't think thats the case. Maybe after many years its possible but most cars and trucks use dual piston calipers now. You want to see something crazy take a look at a 6 piston caliper.
Old 09-01-2011, 01:43 PM
Not the case.
Quote:
There are lots of kits out there from the $700-$1200 price range. WAAAY more than I would spend, but they've got to be selling some because the kits haven't disappeared from the market yet...
Old 09-01-2011, 03:18 PM
Rusty_Old_F250's Avatar
Rusty_Old_F250 Rusty_Old_F250 is offline
Rusty_Old_F250 is gaining momentum as a positive member of FTE.Rusty_Old_F250 is gaining momentum as a positive member of FTE.
I know quite a few older, (usually retired) guys who simply don't want to "fool around" with piecing together something themselves, so they'll happily drop 8 or 9 hundred on a kit that has everything included. They've told me that they've done similar things before and it took forever to get the bugs ironed out, so they just want something to make it easy. I guess it makes sense if you have money laying around, but I don't think very many of us do!
I'd like to know how the dodge calipers work out, my rear drums will need work eventually, and they're too far gone to turn, so rear disks might be a good upgrade to do.
Sam
Old 09-01-2011, 04:43 PM
F250 restorer, what makes you think the dual piston calipers are problematic? Is this model specific? I have never had an issue with dual pistons or more (sportbikes) but if there is a known issue it would be good to know.
On another note, I have found e-brake kits using Caddy calipers for just under $600, so I can't see spending $800+! Any thoughts on the Currie kit? I know Exploders came with 8.8 rear ends, but if there was a way to make it work, that would be great!
E-brake adjustment on 2010 Navigator bbusbee57 2007 - 2014 Expedition & Navigator 1 10-05-2016 02:55 PM
1999 E350 rear dana 60 ebrake plates broke33 1968-2013 Full Size Vans 5 06-07-2016 06:23 PM
Source for 78 Eldorado Brake Caliper E-brake linkage Riderman 1973 - 1979 F-100 & Larger F-Series Trucks 1 09-21-2015 12:59 AM
Rear disc brake tech for F-2/3 or F-250/350 51dueller 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 02-17-2013 09:10 PM
Who Wants Sterling 10.25 disk breaks w/ GOOD ebrake? nstueve 1987 - 1996 F150 & Larger F-Series Trucks 38 09-25-2012 10:30 PM
Tags
1978, 2004, 2500, brake, conversion, disc, dodge, dual, f250, ford, pads, parking, piston, rear, swap, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
