new toyos = big mpg loss?
I put some 285/75r18 Toyo MT's on last week and have since seen a 3.0 - 3.5 mpg loss. I came from 275/70r18 continentals....I knew I was going to see a loss, but I thought more in the range of 1.5-2 mpg's.
I am running the fronts at 65 psi and the rear at 70 psi, Continentals were at 65 psi all the way around.
Has anyone else seen this much of a drop from MT tires? Those of you with Toyos, have you played around with tire pressure and seen better results?
Thanks
Thanks
You didn't mention what you were getting before the tire change, but that is more than a 5% gain in tire size. Your odometer is off by that much now and could account for nearly a 1 mpg difference. A wider, taller and heavier tire is going to kill fuel economy on short distance runs especially. The aggressive mud tire vs. the rather smooth Continental makes a difference as well. I would expect a 2 mpg difference overall and you aren't very far off of that once you figure the odometer difference.
hedhntr
04-11-2006 01:14 PM
