FE Aluminum Intake
FE Aluminum Intake
Hello all. Looking for a used alum intake for my 390. Edelbrock produced several different models, (Streetmaster,Performer,Performer RPM) and I know that some where better performers than others. There's also Weiand, Offy and probably some others I've forgotten here. My question is, has anyone seen any info on which ones were the more desireable, better flowing units and which ones were the dogs? Anyone have personal experience with any of these and were you happy with the results? Any light shed on this would be muchly appreciated.
Happy motoring!
Happy motoring!
There is a fellow named Jay Brown that wrote an entire book on the subject: "The Great FE Intake Comparo" Awesome book if you can get your hands on a copy. Search his name on the Net and here in the FTE forum and see what comes up.
Manifold selection really comes down to what your plans are for the motor and the truck. If you just want to get a 4bbl on it, a factory iron "S" or "T" intake will work fine. They are heavy as sin, but they will be fine for a stock motor. The Edelbrock Performer 390 is also a good choice for a very mild/stock engine, but will be more expensive than a factory iron unit. From there, the Edelbrock Performer RPM 390 is better, but still not amazing compared to some of the high end options. Prices go up from there.
I chose a Performer 390 for my truck. I don't plan on spinning past 4,000 RPM with a stock engine, so it suits me just fine. Gains between the various manifolds under 4k are minimal, so I went cheap. I didn't get an iron one simply because they are heavy
So, what are your plans for the truck/engine?
It'll just be for street use, back and forth to work, cruisin and waking the neighbors. Just picked up a set of Flowtech headers so that will help some, too. I've got a cast iron 4v unit on there now with a new Holley carb but I would like to get the weight down a little using an alum intake.
Check these guys out for pictures: DSC Motorsport
You are absolutly correct. Those other intakes were discontinued for a reason. The FE isnt exactly a race engine, although people tried to make it one back in the day. Dual plane rules in these lower rpm higher torq engines. I'll add this, to torq up the blue viens, a falcon with a 390, a camaro\chevelle with a 350 in the quarter from the same erra... I understand the "I've built a 390 that blew the circuit away arguments, they are 1 in 50 mayby. Just kidding here a little guy's.
Because there is many an FE revving over 6k, and putting out big hp. Some of those discontinued intakes actually perform pretty dang well.
For his application and any heavy truck or barge of a car, the dual plane is the way to go.
I'm not trying to undercut daningraham or anything, but I also have a Perf. intake for sale. $175 + the ride. Just another option. Lemme know if you're interested.
Dp
[QUOTE=Riderman;10796662]
Hmmmm; Not to many suv's making 600 plus hp.
I guess a 434ci "428 bored to 4.170" making 600 hp n.a. and 850 hp with nitrous, turning 7000 rpm, is not a race engine?? I think Barry from Survival Motorsports would disagree with you also. He has built some 700 plus hp n.a. engines.
I agree, if it's a daily driver and you aren't going to use it for anything else you might as well leave the iron anchor on it. You're not gaining anything.
