Door speaker wires, need pics
So I painted my door panels, and before I put them back on I would like to put speakers in the front doors via the holes provided. easy enough.
How do i get a wire to the speaker? There are currently no wires that run to the door and no holes in the door jam.
I can drill a hole in the door and cab, and grommet the holes, but where?
also, what kind of flexable boot can I use to protect the wire? I do not want this to look like crap when I'm done.
looking for ideas, but pics would be the most helpful.
thanks!
thanks!
Here is my setup:
As stated above, there was a dimple in the door jamb on the cab side that I drilled into (right side of second picture). I drilled into the matching spot in the door (left side of second picture, no dimple though). I removed the door to get the proper angle when drilling into the cab.
I protected each hole with a rubber grommet, and then ran plastic conduit in between (this is shown in the second picture). I snaked the wires through the cab inner wall using a coat hanger.
I'd go to the source, DC is cheaper than LMC.
benbuilder
13
05-03-2017 04:02 AM
Fordzilla80
02-03-2010 06:59 PM
