1951 F-3 front wheel bearings HELP!!
I need replacement front wheel bearings for my '51 F-3 in a bad way, does anyone know if these are available anywhere other than the specialty places? I've tried my local auto parts houses and they seem to be useless, so I am hoping that someone might know some part numbers I can take to a bearing supply house that will lead to the right parts. Since my truck is back to working for a living, taking the bearings out to use them as samples is a huge pain in the, well, you know where...Any input is appreciated, thanks for your help!
numberdummy will probably show up with accurate info in a bit. however, in my opinion, if you need these now, pull a wheel and take #'s off bearings and seal. then you can match them up at your jobber. you might try cr seals. i have had very good luck with them for extreme oddball items. maybe joblot in queens, ny. or macs auto supply. don't know where you are located. look for specialty bearing and seal shops or large truck brake shops.
Yep, same for F-1 to F-3, available at NAPA and others. https://www.napaonline.com/Catalog/R...+50028+2028079
Front wheel bearing seal NAPA 17599
NAPA's on-line catalog is excellent and easy to use
1948/52 F1/F2/F3 & 1953/56 F100/250
O1Y-1190-A .. Grease Seal
O1Y-1201 .. Inner Wheel Bearing / BIN: 14130
O1Y-1202 .. Inner Wheel Bearing Cup / BIN: 14276
1948/52 F1/F2/F3 / 1953/56 F100/250 / 1949/54 Ford Passenger Cars
8A-1216-A .. Outer Wheel Bearing / BIN: 09067
8A-1217-A .. Outer Wheel Bearing Cup / BIN: 09195
BIN: Bearing Industry Number...stamped on the parts. BIN's are what autoparts stores/bearing shops go by.
Dozens of these bearings/cups and the seal are available NOS from Ford Dealers/obsolete parts vendors.
sawyersvintage: If you are in SoCal = Engler Brothers Auto Parts, on Pico Blvd. in Santa Monica. The best damn indie autoparts store for older vehicles.
Chain autoparts store (Auto-Zone, O'Reilly's and etc) minimum wage parts-clucks are usually clueless. And, the stores do not have part numbers for older vehicles on their computers.
So, the clucks are usually either too lazy, too stupid, or don't want to bother...to reach under the counter for the printed paper catalogs.
Wow, great response time guys!
While I resent the common idea that most chain auto parts store employees are dumb, I too took a few minutes to look on Autozone.com's website and behold...part numbers and availability. Same with Rockauto...who I generally have great luck with finding obscure part numbers for my customers.
Besides...not all of us Auto Zone folk are dumb...
I don't want to get into the whole parts lackey discussion cause it sickens me...besides, this was about bearings.
fatheroftwo
02-23-2016 09:07 PM
SunnyBeach
04-23-2014 12:37 PM
jccastl
05-16-2007 01:40 PM
nzabka
01-30-2005 01:15 PM
