Don't laugh but you can free those frozen U-joints....... - Ford Truck Enthusiasts Forums
Old 08-30-2011, 07:45 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
4wd front U-joints binding, dry, clacking, causing wheel jerk? , try this; (It works). 1. Go to an empty parking lot with a full can of penetrating oil, turn your wheels to lock, spray joints, go in a circle spray etc etc etc, change directions repeat, repeat, repeat. or 2. Tear a 1' strip of old towel 1" wide, soak it in ATF, run them through you joints and tie the ends so they don't come out and drive like that for a couple days and start by making some tight turns.
My joints were creaking, jerking the wheel big time, etc, 2 years ago and after rejuvenating them with this fix (just took the first one but was slightly better after fix # 2) they have been like new ever since.
Old 08-30-2011, 10:40 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Reps for the tip!
Stewart
Old 08-31-2011, 12:24 AM
Quote:
Originally Posted by Stewart_H View Post
Reps for the tip!
Stewart
Thanks Stewart.
Old 08-31-2011, 11:35 AM
Callmed Callmed is offline
Callmed is gaining momentum as a positive member of FTE.
Def keep that in mind. Thanks
Old 08-31-2011, 03:56 PM
goodmatt2002 goodmatt2002 is offline
goodmatt2002 is gaining momentum as a positive member of FTE.goodmatt2002 is gaining momentum as a positive member of FTE.
Excellent tip! I was just contemplating how to do the very same thing!
Old 08-31-2011, 07:07 PM
HD RULES's Avatar
HD RULES HD RULES is offline
HD RULES is gaining momentum as a positive member of FTE.HD RULES is gaining momentum as a positive member of FTE.
No offense man but if you think about a u-joint and it's design, this doesn't make any sense. How does the oil makes it way past the seals?? If perchance it does make it's way past the seals, the same way in is the same way out. If the joint is binding, the needle bearings are more than likely toasted. Time to change it.
Old 08-31-2011, 07:12 PM
ToMang07's Avatar
ToMang07 ToMang07 is offline
ToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant future
Quote:
Agreed.
And I would add that Penetrating oil and ATF would just dissolve what little grease was left on the probably toasted needle bearings.
Old 08-31-2011, 07:59 PM
Not true, and why is mine acting like new afer 2 years? The light oil makes it's way into the dried grease that is still in there and rejuvenates it. Those joints rarely wear out because they get about a tenth of the action of the rear joint but they do dry out which is the demise of them. I didn't just write my fix because I had a weird dream and woke up with the idea.
Old 08-31-2011, 08:05 PM
Quote:
Originally Posted by ToMang07 View Post
Agreed.
And I would add that Penetrating oil and ATF would just dissolve what little grease was left on the probably ? toasted needle bearings.
That's not true either. You guys knock it without trying it and you leave a little yellow guy shaking his head. The light oil adds to the dried grease and rejuvenates it which gives the needles which are still in good shape but dry a new life.
Old 08-31-2011, 08:08 PM
william_04_x's Avatar
william_04_x william_04_x is offline
william_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputation
Sorry Brent, but this trick didn't work for me.
Old 08-31-2011, 08:17 PM
Quote:
Worked for me 2 years ago and still working. Maybe you didn't do it right, did you try both methods? If you wait too long nothing will help because the grease has dried to the point where the needles finally wore out and broke up. Also, you can't just give it a shot of oil and do a full circle, you have to work with it about 20 minutes but it sure beat putting new ones in for me. Those joints never wear out with good grease in them because they only get probably a fiftieth of the action of the rear ones but they do dry out and don't require much lube to work well but they won't tolerate being dry for a long time with a lot of action on them.
Old 08-31-2011, 08:26 PM
HD RULES's Avatar
Quote:
Whatever works for you man.
Old 08-31-2011, 08:33 PM
Yea, don't try it....just put new ones in.
Old 08-31-2011, 08:46 PM
Probably because you have 2 wheel drive.
Old 08-31-2011, 09:05 PM
Dreamkiller...
I see you looked at your rep. LOL
Steering problem (wheel jerks back and forth) EXv10 Excursion - King of SUVs 305 02-05-2017 06:29 PM
2008 F250 Std. Cab RWD U-Joint swap. TexasRebel 1999 to 2016 Super Duty 0 06-22-2014 11:24 PM
Erratic Steering Diagnosis Tip Argess 1999 to 2016 Super Duty 1 09-20-2012 07:18 PM
04 4wd front end grinding when turning 77f250sc 1999 to 2016 Super Duty 0 05-21-2012 01:52 PM
Freeing your stiff u-joints with no zerks EXv10 Excursion - King of SUVs 0 04-18-2011 03:47 PM
Tags
4wd, bearing, cherokee, f150, ford, free, front, froze, frozen, jerk, joint, joints, suv, universal, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
