P0278 Cylinder 6 Contribution/Balance Fault - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 08-30-2011, 07:36 PM
fordpride's Avatar
fordpride fordpride is online now
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
P0278 Cylinder 6 Contribution/Balance Fault . What is this telling me bad injector,bad wiring, or is this a IDM problem.
I'm pretty sure i know the answer to this
Old 08-30-2011, 08:44 PM
plgebbia's Avatar
plgebbia plgebbia is offline
plgebbia has a good reputation on FTE.plgebbia has a good reputation on FTE.
Probably bad injector, but definately check the wiring first.
Does it have a noticable miss?
Old 08-30-2011, 08:51 PM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
If the wring and the IDM are not suspect & a compression test is good ,I would then suspect the injector ..
Old 08-30-2011, 09:34 PM
fordpride's Avatar
I wouldn't say it's a miss but you can feel a rough spot in the idle about ever two seconds
Old 08-30-2011, 09:38 PM
fordpride's Avatar
I changed the UVCH and pig tails out to the SD style about 3 months ago I'll have to re check my connections.
I have a spare IDM that I'll try for shlits and giggles.
And I'll try my spare CPS just to see if for some reason it helps or moves to a different cylinder
Old 08-30-2011, 09:41 PM
fordpride's Avatar
I did notice this say I'm going 65 mph and give a little go pedal to pass it will act like it has no power till I really get on it. Im gonna pull the chip tomorrow and go from there
Old 08-30-2011, 09:58 PM
fordpride's Avatar
Ok i did another CCT and when it gets to that injector and shuts it down you can defiantly tell that the engine doesn't really change that much not like the rest of them.
Jim do you take blood as payments. LOL
Old 08-30-2011, 10:01 PM
If the engine doesn't change that much ,its not the injector ...
Old 08-30-2011, 10:04 PM
fordpride's Avatar
When it does the CCT does it do them 1-8
Old 08-30-2011, 10:22 PM
fordpride's Avatar
If not the injector then what am I looking at
Old 08-31-2011, 09:01 AM
Make sure the Wiring is intact, & Ohm the injector solenoid first ..
Old 08-31-2011, 09:50 AM
fordpride's Avatar
Will do. I did a buzz test and it passed I also did a WOT run and I normally hit 24 psi I'm down to 18-20psi
Old 08-31-2011, 02:59 PM
fordpride's Avatar
To the TOP for any more ideas
Old 08-31-2011, 03:09 PM
How many miles on your injectors?
Have you observed them while the engine is running ?
Old 08-31-2011, 03:13 PM
fordpride's Avatar
201,xxx not yet I want get to really rip it a part till this weekend just trying to get a list of things to check when I get off. I'm gonna pull the chip before I leave work
P0278 code cylinder 6 MalcolmD682 6.0L Power Stroke Diesel 6 05-07-2016 02:42 PM
P132B, PO278, PO401 grantpage 6.0L Power Stroke Diesel 7 11-12-2012 10:10 PM
Error P0266 Cylinder 2 Contribution/Balance Fault bkvanbek 6.0L Power Stroke Diesel 3 12-22-2010 10:48 PM
Code p0284 cylinder contribution/balance fault jeremy53402 1994.5 - 1997 7.3L Power Stroke Diesel 4 06-29-2008 06:46 AM
Code p0284 cylinder contribution/balance fault jeremy53402 1999 - 2003 7.3L Power Stroke Diesel 4 06-28-2008 09:03 AM
Tags
2004, 60, ac, balance, code, cold, contribution, cylinder, diesel, f250, fault, ford, imbalance, p0278, p0284, power
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
