99' V10 Hydrolocked Coolant in oil - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-30-2011, 01:16 PM
Roger Samford Roger Samford is offline
Roger Samford is starting off with a positive reputation.
I have 319k on my truck, no major repairs, just coil packs, alt, Radiator, Hubs. Head pitted around the water neck and leaked coolant and has been patched with JB weld for over 200k. I drove my truck home from work Friday and there was no problems. I went to start it up Sunday and it went Thunk. I had a couple of probs with the starter some I installed a new one on and it did the same Thunk. Let down of jack stands. Yes it is 4X4 but I'm fat and needed the extra room for my belly. Turned the key and it turned over, but I had to pump the gas" never had to do before" It started. Noticed steam coming out of exhaust and shut it down. My question is This trck has only been hot 2 yrs ago when I had to replace my Radiator. I know the obvious answer is the Head Gasket, but I have heard that there were problems with the intakes pitting and developing leaks. Is this true? What steps would you recommend I take to insure proper diognoses. I would hate to have to pull the heads and rplace the gaskets if not needed really dont want to pull the motor. Note that my oil is not milky and truck ran great when I parked it 2 days prior. Any help would be greatly appreciated.
Old 08-30-2011, 03:52 PM
Pili's Avatar
Pili Pili is offline
Pili is starting off with a positive reputation.
do compression and leak down tests and go from there
Old 08-30-2011, 04:12 PM
SteveH-CO SteveH-CO is offline
SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.
A faster/cheaper test might be to do a pressure test on the cooling system, and if it will not hold pressure and has no visible leaks, you can be pretty sure it's a head gasket. Restarting it and seeing more steam from the exhaust would tend to confirm, after this pressure test.
this 302 is a money pit tweakerford 1987 - 1996 F150 & Larger F-Series Trucks 6 03-07-2015 01:25 PM
7.3 IDI - High Coolant Pressure and Leaking Head Gasket mytoys2037 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 06-18-2013 12:40 AM
Simplified 6.0 events........ matty169 6.0L Power Stroke Diesel 22 01-03-2011 08:56 PM
HELP! Aesthetikz Aerostar 17 08-27-2010 07:52 PM
1986 F-150 302 Ticking Noise venom_99 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 05-30-2004 06:46 AM
Tags
10, 2001, coolant, cooling, engine, f250, ford, gasket, hydrolock, hydrolocked, oil, radiator, system, triton, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
