What have we done to our trucks today B.C.?
#121
Towed mine to the body shop for the frame off.
Attachment 289691
Chris do you have any bumps at Jim's yard? I need a small section of the stone shield.
Attachment 289692
Attachment 289691
Attachment 289692
#123
And yes I am putting on a new cab. Mine's rotted around the drip rail. I'll probably end up piecing the two together.
#125
I need a little 2-3" wide piece (even that's more than I need) and ideally I'd also like a couple bits to fill the frame notches on the stone shield. I can always make them myself but using OEM body lines makes life much easier.
And yes I can do that. I'm doing all the bodywork and the paint on my truck. I'll let the pictures do the talking. Here's a rocker panel I made.
#127
Colour doesn't matter. I just want something not rusty. To tuck the front end I'm going to have to cut it across the length of the stone shield, but because it's tapered where it meets the fender, when I move it in it won't be wide enough. I'll have to cut the stone shield in the middle and insert a small piece to widen it. That's what I need it for. So if there's a bump in his yard with a crappy and otherwise useless stone shield that happens to have a really nice section that's a few inches wide, I'd appreciate getting that little piece.
#134
Alrighty, thanks for looking. I struggled to pull mine off today. Had to pull out the grinder.
Attachment 289687
Attachment 289687
