What have we done to our trucks today B.C.? - Page 4 - Ford Truck Enthusiasts Forums
British Columbia British Columbia
Join Chapter, Leader: sky Cowboy
  #46
Old 02-09-2012, 08:17 PM
PilotPete PilotPete is offline
PilotPete is starting off with a positive reputation.
Just pulled in at Silver Star, unpacked, beer in hand! Now where's that hot tub?!
Pete
  #47
Old 05-25-2012, 08:09 AM
429unibody's Avatar
429unibody 429unibody is offline
429unibody is gaining momentum as a positive member of FTE.
Zip did you find a Exhaust manifold?
  #48
Old 05-25-2012, 02:22 PM
Zip's Avatar
Zip Zip is offline
Posting Legend
Zip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputationZip has a superb reputation
Yes I did. Got one from a place in Lethbridge. That truck and the 66 are now for sale.
  #49
Old 05-26-2012, 12:39 AM
429unibody's Avatar
How much you asking for the Merc?
  #50
Old 05-26-2012, 12:43 AM
429unibody's Avatar
I got started on the foundation walls forms for my shop today
  #51
Old 05-26-2012, 06:55 AM
Zip's Avatar
Zip Zip is offline
Posting Legend
Asking around $1400.00 obo for the pair.
  #52
Old 06-02-2012, 10:29 AM
429unibody's Avatar
Quote:
Well if you still have them down the road I'll see what I can do ,would love to add them to my collection
  #53
Old 06-27-2012, 05:04 AM
Zip's Avatar
Zip Zip is offline
Posting Legend
Changed a wheel cylinder on the bronco. Put on a different master cylinder. Repaired a line at the master cylinder. Have the intake ready to pull off in the morning.
  #54
Old 06-28-2012, 07:54 PM
highnwild's Avatar
highnwild highnwild is offline
highnwild is starting off with a positive reputation.
My 76 highboy
New front brakes, axel seals,pinion seal, tie rod, upper and lower ball joints both sides, front axel u joints, repacked hubs and bearings, need to replace seals on assisted power steering ram, but would prefer to go with power steering conversion kit, Wow there expensive, dont wanna rob any parts of my 79, it is gonna be my daughters truck so might have to swallow the 1000 dollar conversion unless someone has a better idea.
  #55
Old 07-16-2012, 01:01 AM
R031Kona's Avatar
R031Kona R031Kona is offline
R031Kona is gaining momentum as a positive member of FTE.
I did a engine swap from my parts truck into my Ranger last month.... .unfortunately just the same engine a 4.0L
  #56
Old 07-18-2012, 05:07 AM
Zip's Avatar
Zip Zip is offline
Posting Legend
Want to buy a 429 Andy. It should almost fit.
Now have working signal lights on the bronco. Changed the fuse and both front harnesses. Replaced a rear tail light assembly. Flipped one head light. Mounted upside down. Put on different antenna.
Next on the list is oil change, drivers side outside door handle, get rear window operating better or replace the whole tailgate. Need to put in a stereo. No where in town sells them so will have to wait till the next road trip.
  #57
Old 08-28-2012, 11:11 AM
HardkaseDaddy's Avatar
HardkaseDaddy HardkaseDaddy is offline
HardkaseDaddy is starting off with a positive reputation.
replaced the head gasket on my E250 this summer. I don't like working on van engine compartments.
Jut finished rebuilding the door for my '73, after painting it. Still got some trim to put back on it. I loooove metalic lime green.
  #58
Old 08-29-2012, 03:21 AM
R031Kona's Avatar
Always liked big blocks...... hmmmn
  #59
Old 09-05-2012, 04:51 AM
Zip's Avatar
Zip Zip is offline
Posting Legend
I got the box ready to bolt back on the 75.
Fellow brought in a couple 66 pu's. One is a shortbox. No box though, not much more than a cab. The second is a cab and box. The frame is hooped. Got the mind working. If my two others don't sell I have a good frame with crappy body and box, a strong running 352 and good 3spd. tranny. That's one option, probably the smartest. The second truck has very little rust on the cab and pretty much none on the box.
Now me being a 4x4 lover. Putting cab and box on mid 70's frame with a 429 and a 4spd is option two.
  #60
Old 09-08-2012, 10:16 PM
no replacement for displacement!
Why? New Truck! Died with only 1000 miles MYTRUCKNOWRATTLES 6.7L Power Stroke Diesel 34 10-20-2015 12:48 PM
Best oil for my engine holyspirit 1994.5 - 1997 7.3L Power Stroke Diesel 5 06-05-2015 11:06 AM
Repeated starting problems GLOBALSDF 1987 - 1996 F150 & Larger F-Series Trucks 16 06-03-2015 02:37 PM
Tires,shocks Need info. Ford dad Excursion - King of SUVs 12 03-14-2015 10:50 PM
Truck cap + sliding window ihbond 2004 - 2008 F150 4 11-23-2004 10:00 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
