Tucked it in a couple inches. Both end pieces are mocked up. Just have to do the center sheet metal and then double check everything before final welding.
I might was it. The big white one that is. I might fire up the Bronco if I can find the elusive battery charger. I need to remember that it is still February though. It wants to come out of hiding but still too early. Maybe I need to take something apart so it can't.
Got the Bronco out last week. Put a new brake bleeder valve on and now have some brakes. Ordered a passenger side floor pan as it seems to be getting a little punky.
Going to get the Bronco ready for an engine pull. Well not really a pull. Have to slide it ahead a few inches so I can change the clutch fork. Will drop one side of my exhaust at the same time to fix a small issue with it.
