PCM Wiring
PCM Wiring
I have just completed an engine swap into my 86 BroncoII. The donnor 4.0L engine came from an 93 Explorer with auto trans. My B2 is a manual so I needed to convert the engine (flywheel, pressure plate, etc) to a manual. I was told that I also needed a PCM for a manual 93 Explorer, and purchased it.
However, the engine ran but very roughly. I checked the codes and it stated that the MAP voltage was low. I checked the wiring from the MAP to the PCM and found that the wires did not go to the pin locations on the PMC as stated in the electrical manual. (there are other wires not in the locations listed in the electrical manual)
Can't understand why? The engine ran with the auto PCM with wires in the different location from the electrical manual, but not with the manual trans PCM. Should I change the pin locations to the locations listed in the electrical manual?
dieselsubmariner
37
06-18-2013 08:38 AM
bostonpowerstroke
08-22-2010 04:28 PM
55 f350
05-21-2009 07:38 PM
