1966 power steering - Ford Truck Enthusiasts Forums
1966 power steering
Old 08-29-2011, 09:00 PM
66CustomCab 66CustomCab is offline
66CustomCab is starting off with a positive reputation.
1966 power steering
I found a guy who has a 1966 power steering box, pump, & bracket for sale. what else would I need to add power steering to my truck.
Old 08-29-2011, 09:37 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Don't consider it, because you don't want it...it's awful Bendix P/S.
No replacement parts are available for Bendix P/S except the master seal kit (and then only from obsolete parts vendors).
If you can find one...figure 100 bucks EZ.
1966/68 F100/250 2WD / 1969 F100/250 2WD before serial number D96,001 used Bendix P/S.
1969 F100/250 2WD & F350's from serial number D96,001 used Ford (Saginaw) P/S, which was then used into the 1990's.
There are 1000's of posts here on FTE that explain how to install Ford P/S on these trucks.
Old 08-29-2011, 11:01 PM
Broomfieldbum's Avatar
Broomfieldbum Broomfieldbum is offline
Broomfieldbum is gaining momentum as a positive member of FTE.
I read a ton on this issue when my steering gear went out, and one thing I can tell you is all the post say the Power Steering column is slightly shorter, and therefore you have to replace the column. That and the Bendix issue convinced me to abandon that idea. I replaced or rebuilt everything in my 66 from the wheels to the steering wheel, and my truck now drives like a dream. I cannot believe that manual steering can be this easy to drive. I guess I never drove a manual steering box that wasn't half trashed. I drive with one hand most of the time, and I have 3 on the tree. It changed my trucks drive ability about 99%
Old 08-30-2011, 02:12 AM
Jetcopterpilot's Avatar
Jetcopterpilot Jetcopterpilot is offline
Jetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputation
Quote:
Agreed! I rebuilt mine, and it does drive so easy that I don't see the point in having power steering... It really is a testament to the design of the period!
Old 08-30-2011, 08:38 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
I have power steering on my '66 and it's fine. However, on my '60, I do not but it has been completely redone and steers just as nice as power! It has a different feel but even with the old straight axel it is great. I say all that to encourage rebuilding your existing.
Old 08-31-2011, 05:58 AM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
You don't get much from power steering on the hi-way, where it shows up most is at idle, turning in & out of tight places, backing trailers, and the like.
I don't disagree the latter posters, but I aint giving my PS conversion up. I like it.
John
Old 08-31-2011, 12:11 PM
Thanks for the input guys. Sounds like I should hold off on this one.
Old 08-31-2011, 01:44 PM
Yeah I can understand Power steering if your teenage daughter, or grandma is going to drive it. I tow my boat, and toy hauler with my truck, no problem, and I live by the beach, so parking can be tough, and I have no problem with the manual steering, nor do either of my kids. So put your money where it is needed more! As long as you maintain your steering properly, it will take care of you. As John (Jowilker) said "You don't get much assistance from power steering on the highway, but where it shows up most is at low speed!"
Old 08-31-2011, 02:22 PM
Quote:
What did grandma's do before P/S was first offered (in 1951 Chrysler's)?
Drove w/o it...and some a those old piles of misery grandma's drove had massive 18-24" wheels, rudimentary front suspension....steered worse than any Slick.
IMO, you don't need P/S unless you do a lotta parallel parking. With properly inflated tires and with steering/suspension up to snuff, even kiddies can drive w/o it.
Old 08-31-2011, 04:21 PM
The main reason I'm interested in P/S is that I end up doing a lot of parking in tight parking lots when I take the truck out. It's a long bed, which makes it worse than most. Some lot aisles are only 25 feet wide or even less. I can armstrong it, but then the steering wheel itself suffers. I've put more than a few cracks in the 2 I've had on it. It'd be nice to 'one-finger steer' it, especially in stopped, tight manuevering situations.
Old 08-31-2011, 04:36 PM
jmf66's Avatar
jmf66 jmf66 is offline
jmf66 is starting off with a positive reputation.
.. and I believe the Power Steering box is a little quicker ratio.
Old 08-31-2011, 06:01 PM
StevenhF100's Avatar
StevenhF100 StevenhF100 is offline
StevenhF100 is starting off with a positive reputation.
Drove my first 65 for 25 years before I put power steering in it. Don't know why I waited that long, it's the first thing I do to mine now. You can also swap out the steering wheel for a smaller one if you have ps. More room the "extra sized" new me.
Old 08-31-2011, 06:31 PM
jowilker's Avatar
Yall leave my grandmother alone. I don't know if she ever drove a car. Hell with 13 children she didn't have much time to go places.
I like my power steering and I'm sticken with it, I don't care what yall say.
John
Old 08-31-2011, 09:18 PM
I think we can all agree, that to put power steering in requires a replacement steering column, and gear, and all the power items and mount brackets. For some people all the work is worth it, for others it is not. I am a near purist in my truck. It didn't come with power, so I won't add it now.
Old 08-31-2011, 09:20 PM
spurredon's Avatar
If your steering is so stiff that you are tearing up steering wheels, you really ought to look at your king pins etc... Power steering is not going to replace a front end that is in need of repair!
1966 F100 Steering Column Advice thumper7741 1961 - 1966 F-100 & Larger F-Series Trucks 4 09-28-2014 09:35 AM
Wanted power steering for 1966 N750 GJCAT Large Truck 2 04-15-2014 06:15 PM
1966 f100 steering TheRick505 1961 - 1966 F-100 & Larger F-Series Trucks 10 04-01-2014 12:46 PM
1966 f100 power steering conversion? Maryrylee 1961 - 1966 F-100 & Larger F-Series Trucks 12 08-26-2013 09:53 AM
F100 1966 Automatic Steering Column breablvd 1961 - 1966 F-100 & Larger F-Series Trucks 10 04-11-2006 06:36 AM
Tags
1966, f250, power, ratio, steering, thunderbird
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
