Plenum vacuum motor - Page 2 - Ford Truck Enthusiasts Forums
Plenum vacuum motor
Old 07-18-2012, 08:16 AM
Kim B Kim B is offline
Kim B is starting off with a positive reputation.
Was the sticking door issue resolved I have the same problem.
Kim
Old 07-18-2012, 08:33 AM
parr4 parr4 is offline
parr4 is starting off with a positive reputation.
Hi Kim
Yes it is 'fixed'. What I did was park truck behind car instead of into the Sun. It was a heat problem which was prolly exacerbated by a new dash cover I'd installed the season before.
Anyway, truck is parked facing North instead of West. All fixed!
What problem are you experiencing?
Old 07-18-2012, 08:48 AM
Same issue but I can't park it out of the sun I am trying to keep from pulling the dash all that plastic is old and brittle.
Old 07-18-2012, 09:07 AM
I understand 'old & brittle'! What vehicle? The whole AC/Heat system is run by vacuum, so that's where to start. Hoses, vac motors and the function switch.
Old 07-18-2012, 12:25 PM
It is an 1981 f350 4x4 regular cab bought it new been dealing with this a few years now. Just got back hauling hay with it a/c works fine but wasn't sunny when I started so I was good.
Kim
Old 05-07-2014, 03:50 PM
Since I first posted this thread, I'd thought the problem was solved. I was wrong. It started happening now and then but would always 'fix itself' somehow. Thought the heat was the cause of the problem..not.
Recently it's been getting hot again and sure enough, the problem started again. Went through all the checks I could but everything worked as it's supposed to. I"d fixed the door hinge problem 20+ years ago, so I finally decided it had to be the same issue.
First cloudy/cool morning, yesterday, I removed the heater core cover and was able to watch the door move....exactly as it is supposed to. I did notice a 'hitch' in the vacuum motor movement tho. I was able to get my hand into the door compartment and felt a kind of jagged 'something' at the connection point of the vacuum motor arm. Got a mirror and light to see what I was feeling and saw the pin that secures the motor arm to the door was ajar. The door connection has lower and upper pivots, the motor arm goes in between those pivots and pin secures the arm. The pin had worked itself out of the lower pivot! Pushed the pin into the lower pivot, lubed it some and voila! Fixed....again! (doesnttakemelong)
Old 05-08-2014, 10:35 AM
1986F150six 1986F150six is offline
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
Thanks for the update and adding to the forum members collective knowledge!
Old 05-08-2014, 02:29 PM
Thanks. Glad to help. That little pita pin problem had been frustrating me for 2yrs.....but I'm feeling MUCH better now!
Old 05-02-2015, 11:47 AM
hmmm....not as 'fixed' as I thought. Starting to happen again. Last time I was able to get my hand into the area and 'feel' for the pivot pin. Able to push it down to overcome the problem but not a permanent repair. My 1-hand repair method worked but not neary as long as I hoped. Need 2-hand method...
Plenum area of concern assessable from dash top?
Anyone have a pic of the pivot pin area I'm dealing with? Is the pin plastic?
A better repair method?
Thanks for any help/advice about this pita problem.
Dave
Door Panel's fading from Sun Delawhere? 1999 to 2016 Super Duty 3 12-10-2016 08:13 PM
problem solved! 97 aerostar heater/AC blower turns off and on randomly tfenny Aerostar 6 10-28-2016 09:38 AM
Vacuum Wipers BaggedMerc 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 09-12-2015 10:39 AM
Boost Leaks! Can I tighten? Help? ExPACamper 1999 - 2003 7.3L Power Stroke Diesel 25 07-28-2015 01:50 PM
Driver's door panel and liner off... what should I fix and how? Y2KW57 1999 - 2003 7.3L Power Stroke Diesel 28 05-29-2015 02:07 PM
Tags
080457s, 1980, 1994, 2005, ac, checking, defrost, engine, f150, ford, motor, plenum, truck, trucks, vaccume, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
