05' F250 5.4L V8 gas Converter problems - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-29-2011, 05:59 PM
MDRalya MDRalya is offline
MDRalya is starting off with a positive reputation.
I have a 05' F250 5.4L v8 gas Fx4 package w/ 97,000 MI.
When i bought it someone had put a K&N filter system on it that i keep clean regular My check engine light was on and I had to replace all my spark plugs and coil packs 3 of which were seized up. Now my Converters are bad.
Just wondering what people think of the K&N clean and oil filter VS. the one you can clean with soap and water and no oil? Also I am thinking of doing straight pipes and eliminating the converters but don't know what to do about the sensors and the computer. I am looking at getting a chip to program the computer but they are so expensive. I am at the point I cant really afford the converters because they have to be ordered from ford and the chip is not cheap. Oh ya my mileage has gone from about 14 or 15 to about 10 or 11 mpg now it is killin me and I have no power going up hill now.
I hope to get some good ideas anything helps. Thanks!! Also does anyone think the K&N filter could have caused all these problems if so what would you reccomend instead? I was also lookin at the FU chip if anyone has heard of it off of power hungry perf.
Old 08-29-2011, 08:33 PM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
The most popular gas engine tune on this board is a custom tune from 5 Star.
I use the K&N replacement filter. It works well for me. Some say it doesn't work well but I have run them on multiple gas engines without issues.
AFAIK, there is not a sensor downstream from the catalytic converter, so deleting it should not be a huge issue. Just do it.
You will also want to look at replacing the restrictive Y-Pipe.
Old 08-29-2011, 08:54 PM
adbanshee adbanshee is offline
adbanshee is starting off with a positive reputation.
The biggest problem is people over oiling K&N air filters, this can lead to oil droplets burning on the Mass Air Flow sensor, which leads to carbon build-up. This build-up acts as an insulator on the wire causing the ECU get an inaccurate signal. This, obviously, is going to give poor performance and economy, and could damage the cats and the O2 sensors.
Old 08-30-2011, 12:11 AM
Robs06SuperDuty's Avatar
Robs06SuperDuty Robs06SuperDuty is offline
Robs06SuperDuty is gaining momentum as a positive member of FTE.Robs06SuperDuty is gaining momentum as a positive member of FTE.
The cat's on my 06 F250 5.4L burnt out at 17,000 miles (I bought the truck new in Sept of 06) I was getting abt 5-6 mpg at the time and the truck has Zero power. Lucky warranty took care of the problem, but I think it has returned again... truck just doesnt seem to have the power it did, unless its just this horrible "gasoline" we have now I days... yet again its got 92K on the clock.
I run a K&N CAI on my truck and love it, havent had any problems with it at all... just have to clean it more often than the drop-in filter in the stock box. Doesnt hurt to take your MAF out every once in a while and clean it.
Redford: The 05 and up trucks have a different Y-pipe design than the 1st gen super duty's, the y-pipe is much less restrictive. no need to replace it.
Old 08-30-2011, 08:42 AM
Furian's Avatar
Furian Furian is offline
You Keep What You Kill
Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.
I believe that Ford extended the emissions warranty to either 100K or 120K... contact your local dealership for confirmation.
Old 08-30-2011, 02:54 PM
Furian: I think its 100K
Old 08-30-2011, 04:14 PM
mwsF250 mwsF250 is offline
mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.
It is sooooo rare for a cat to "go bad" these days. What happened to them?
And do check with dealer. Cats are definitely emissions related items with extended warranty.
Regarding air filters: Premium paper (Napa Gold) is all I will use. I usually keep vehicles for well over 300K miles so need good air filtration.
Old 08-30-2011, 04:29 PM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
In CA the emission systems have mandatory 10 years warranty. That is main reason why CA models are more expensive.
K&N filters are famous for letting more air and more dust coming through.
When more air is good for the engine, the more dust is not. I heard the "I never had a problem with them" thousands of times, but none of those statement come backed up with oil test showing no dust (silica) in the oil. I do have severe duty OEM filter in my truck and almost 90,000 miles on the element. The vacuum indicator only lately shows some clogging , while several oil test prove perfect filtering.
Additionally the oil AND dust coming from the K&N can and will foul MAF (regardless what salesmen say) what in result will create engine mismanagement, poor performance and dumping raw gas into the cats.
Did I mention that dust create grinding effect on pistons and cylinders?
Old 08-30-2011, 05:41 PM
jc8825's Avatar
jc8825 jc8825 is offline
jc8825 is gaining momentum as a positive member of FTE.jc8825 is gaining momentum as a positive member of FTE.
Quote:
What octane do you have up there? I know when I vacation in Colorado, the Regular Unleaded there is 85 octane, which is too low for newer vehicles. Maybe the octane is too low for the Regular Unleaded where you are?
Old 08-30-2011, 06:05 PM
redford's Avatar
Catalytic converters do go bad, causing excessive back pressure and a huge loss of performance.
You may want to double check the emissions warranty. Vehicles over 8500 pound GVWR are not governed by the same laws as passenger cars. I think the emission control warranty is only 50,000 miles for us.
possible coil, spark plug, or fuel injector problem? cem1985 1999 to 2016 Super Duty 7 03-24-2012 05:05 PM
blown 5 amp interior fuse for dash lights leiteralex 1997 - 2003 F150 3 03-19-2012 08:50 PM
What converter to get? Trans need to be rebuilt now? dragstang86 1999 - 2003 7.3L Power Stroke Diesel 10 10-29-2011 09:53 AM
gas tank problems Jeffery the first 1987 - 1996 F150 & Larger F-Series Trucks 1 03-08-2011 05:30 AM
***** 5 Star 2011 BOSS 6.2L V8 Custom Tuning NOW Available ***** fordmdb Vendor Specials, Discounts, Product Announcements & Group Buys 6 07-07-2010 07:48 PM
Tags
05, 54, f250, ford, ford54lv8reliability, gas, power, problems, taking, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
